Help!!
Old Jun 3, 2009 | 08:02 AM
fmc400's Avatar
fmc400
MSEE
If the starter solenoid is clicking, it's at least getting (some) power. Is it clicking once, or chattering? Check the battery voltage using a multimeter. Have you cleaned or replaced the negative battery cable yet? Where does your negative battery cable run? What is the condition of the starter cable? There are some other things to check after you check these.
You sound new to trucks, so let me clear this up early: just because something is brand new does not mean you should eliminate it from diagnostics. Assume you know nothing about the condition of the parts and check everything step by step. In other words, if someone tells you to check something, don't ignore the advice by saying the part in question is brand new.
Originally Posted by 76f350spercamprspeal
And when you put in new gas put in the highest octain you can..
Wrong.
Old Jun 3, 2009 | 09:13 AM
75F350's Avatar
75F350
You stated that you poured oil into the cylinders? Did you install the plugs back in? If the engine did actually turn over and a cylinder is full of oil, then you may just have a hydraulic locked situation. If you did this in the exact order that I read them, then this is likely the case. Remove the spark plugs and attempt to turn thr engine over again.
If the engine turned over slightly, then it will move and it is not "locked up" so you should be able to get it to turn.
Old Jun 3, 2009 | 09:48 AM
Ramoyer1's Avatar
Ramoyer1
oil i poured MMO after it stoped turnin over. All plugs are removed. Yes i started at the battery and worked down.
Battery is 800cca battery brand new.
The solenoid Clicks over but nothing more sounds or anything happen.
so we pulled the starter thinking that was the problem.
Starter tested out great.
My brother said that the + wire was getting really hot and a lil smoke was coming off it when we turned the key.
Reinstalled the starter
Fixing the gorund cable with brand new 2 gauge wire.
Old Jun 3, 2009 | 06:09 PM
fmc400's Avatar
fmc400
MSEE
While I doubt the battery is the problem, you're ignoring the above advice and not diagnosing this issue properly. It's somewhat of a moot point here, but just FYI.
If the positive battery cable was smoking, too much current is passing through it; and if this starter otherwise checks out fine then it's likely having to work too hard to turn the motor over. It sounds like the motor is locked up; refer to 75F350's post to verify.
Old Jun 3, 2009 | 06:19 PM
shanes66charger's Avatar
shanes66charger
Absolutely NO reason to use anything but 87 octane. Higher octane is just harder to light and produces less energy when burned.
As for your issue.........try another battery. It may have a dead cell, etc.
Hard to believe the motor would LOCK UP in just a year. Mine sat for years and years and runs mint.
Possible the previous owner toasted it and is not telling you something.
cheers
Old Jun 3, 2009 | 07:22 PM
Ramoyer1's Avatar
Ramoyer1
LOL IT RUNS!! it was bad + wires,and the motor was stuck. The MMO took care of the hung up pistons and the new wires fixed the others!
Old Jun 3, 2009 | 09:07 PM
nutinbutford's Avatar
nutinbutford
Congrats! glad to hear you got it figured out. Now go get a cam, hedders, set of magna flows, and some 3" exhaust and send us a youtube of she sounds
Once again the helpful bunch here on the forum worked through another challenge.
Old Jun 3, 2009 | 09:08 PM
Ramoyer1's Avatar
Ramoyer1
lol it is a 460 crate motor! it sounds like it has a cam alrdy in it. I will post vid in few mins!
Old Jun 3, 2009 | 09:12 PM
Ramoyer1's Avatar
Ramoyer1
i know the rpms are a lil low i will get a better one when i got 2 ppl out there.
Old Jun 3, 2009 | 10:30 PM
Ramoyer1's Avatar
Ramoyer1
Old Jun 4, 2009 | 06:15 PM
76f350spercamprspeal's Avatar
Wrong.
Why is that wrong,explain it to me...
Old Jun 4, 2009 | 07:34 PM
fmc400's Avatar
fmc400
MSEE
Gasoline will ignite on its own given enough compression. The higher the octane rating, the more it can be compressed before it ignites without a spark. If a motor runs fine on 87 octane (as is the case with many stock, relatively low-compression motors), then increasing the amount of octane does nothing except waste money. Higher octane fuel is for higher compression engines.
berlincam86
33
Feb 27, 2011 07:16 PM
chucky0094
Aug 31, 2008 08:34 PM
DubDub
1983 - 2012 Ranger & B-Series
19
Jan 28, 2008 04:36 PM
schlager
May 15, 2006 10:37 PM
big1
Mar 18, 2003 01:11 PM
