Backup Camera
Old Oct 7, 2010 | 02:31 PM
  #46
Bowie's Avatar
Bowie
What was the ending here. I looked on sams club website and they are no longer available. I am going to get a camera and I dont know which ones to get?
Old Oct 7, 2010 | 03:40 PM
  #47
Trucky2's Avatar
Trucky2
You can get most any day/night weatherproof camera and make your own setup. I got a camera for $16, 30' of camera/power cable and plugged it into my Pioneer DVD player. Works great. There's a ton of LCD displays out there but finding a decent place to mount one is the challenge. I got a 10.2" LCD/RearView Mirror thing that worked great but ended up replacing my factory radio with the DVD unit, mostly because I'm a bit OCD about factory look. Still have the mirror monitor if anyone is looking...
Old Oct 8, 2010 | 10:25 AM
  #48
Bowie's Avatar
Bowie
Where did you get the camera, and wire? I want one where I can see the trailer hitch ball but also see behind the truck well.
Old Oct 8, 2010 | 10:46 AM
  #49
Trucky2's Avatar
Trucky2
Here is the same one I got from eBay for $15, including shipping:
3.6mm Wide Angle Car Rear View Reversing Backup Camera - eBay (item 250704298536 end time Oct-29-10 21:58:35 PDT)
And Wally World has the 33' cable for about $9:
Walmart.com: SVAT 33' Shielded Extension Power/Video Wire: Computers
I ended up coiling a few feet up with my short bed crew cab.
A few notes about my installation... I put the camera into the bumper, just left of the license plate and below the spare tire hole. This gives me a good rear view but I can't see the top of my hitch. I guess I got a little ahead of myself and drilled the hole while I had a chance to borrow a 1 1/4" step bit and a 1/2" drill. After a little bit of testing I found the best location to be between the hitch and the 7/4-way plug. I want to fab a bracket to fit to the right of the plug arrangement, with about 10 degrees of back tilt to mount the camera in. This would give a perfect hitch ball view but does take away a bit of the overall rear view. It's all in what you need to see. Even where mine is I can hook up trailers soooo much easier now. The camera listed above has a couple angled mounting rings so you can adjust it's perspective from a flat hole.
Old Oct 8, 2010 | 11:50 AM
  #50
Bowie's Avatar
Bowie
This is awesome thanks Ken, How long have you had it installed? No problems I am assuming. I guess it is not biggie if you did have a problem, just buy a new camera. That is cheap. I am going to order right now. I was going to buy one for 50 bucks and I thought that was cheap. Boy was I wrong, my wife tells me that all time I just never listen. Maybe I should listen. NAAAAA
Old Oct 8, 2010 | 12:22 PM
  #51
Trucky2's Avatar
Trucky2
Hah, I understand totally. I see something I know I think I need and believe I should have it tomorrow. Then the research side of my brain kicks in and I usually over research everything. I deal in video surveillance and know cameras and figured this cheapy camera wouldn't do well but what the heck. It does great, considering. The night vision is not bad either.
VaSheriff
Dec 18, 2019 03:58 PM
stevepetro
Aug 5, 2014 04:33 PM
sredmyer
Oct 28, 2011 12:07 PM
shockr
2004 - 2008 F150
Nov 28, 2008 07:18 PM
