Fault code PO123
Jun 2, 2009 | 11:08 AM
Fault code PO123
Okay, I've tried all that I know. Even searched on here before I posted this thread. Here is the issue...
Check Engine light comes on
OBDII reader says PO123
PO123 = TPS
Replaced TPS
Reset/erased code
after about 15 min, check engine light re-appears
Check, same code PO123
erased and same result
Check wiring, cleaned connectors all good
Cleaned AFS
Result... same
Go to Ford Truck Forums and seek help!
Any ideas? I'm open to suggestions!
Jun 2, 2009 | 12:07 PM
whats the year and make eng ect.
Jun 2, 2009 | 12:15 PM
You may want to check the D P F E sensor
Jun 2, 2009 | 12:18 PM
Quote:
Originally Posted by
aastrotran
Okay? Not sure what those are...
It's a 98 5.4L w/auto 4.4 E.B. package.
Thanks
Jun 2, 2009 | 12:33 PM
differential Pressure Feedback Exhaust Sensor located on the right side top of engine
Jun 2, 2009 | 12:37 PM
aastrotran
Is there a diagram somewhere showing the location. I am hearing a slight exhaust leak, could that be coming from there? If so, it may be broken/leaking causing the whole thing.
Jun 2, 2009 | 01:25 PM
Jun 2, 2009 | 07:48 PM
luelani
That link isn't even about a Ford system. I'm pretty sure it's not going to help....
Here is the first step of the diagnostic for the exact vehicle in question:
<title>Throttle Position (TP) Sensor</title><link href="VWA%7Eus%7Een%7Efile=VWAstyle.htm%7Egen%7Ere f.htm" type="text/css" rel="stylesheet">
Quote:
DH8 DTC P0123 OR P1124: ATTEMPT TO GENERATE THE OPPOSITE THROTTLE POSITION ANGLE (VOLTAGE) PID READING
ShaneNP123
135
Aug 15, 2017 07:51 AM
2006f150bk
2004 - 2008 F150
May 2, 2017 01:16 PM
Jmurphy5
1997 - 2003 F150
May 12, 2016 12:35 PM
tomeug69
Dec 10, 2015 08:48 PM
zyskm81
Dec 11, 2010 12:32 PM
123 ,
1999 ,
2001 ,
2006 ,
check ,
code ,
codes ,
cylinder ,
diagnostic ,
engines ,
expedition ,
explorer ,
ford ,
po123 ,
ranger ,
sensor ,
sport ,
trac
