Sponsored by: Real Truck
2002 A/C questions
Old Jun 2, 2009 | 09:55 AM
rem260man's Avatar
rem260man
2002 A/C questions
Folks
I have a 2002 F-250, CC, 4X4, V-10, with 175,000. During the very hot afternoons the A/C quits cooling for a few minutes. It will start bak up again and will work great. On the not so hot afternoons and the cooler mornings it is not a problem. I have never pulled over when it wasn't cooling to see if the compressor was on or off.
Any ideas before I pay the big A/C shop guys?
Thanks in advance,
Lee
Old Jun 3, 2009 | 11:29 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I wonder if it's just working way too hard and it went over-pressure?
Did you check the condensor in front of the radiator and make sure it's clear of dirt/debris?
And what setting do you have it on? AC or Max AC?
Old Jun 3, 2009 | 07:05 PM
projectSHO89's Avatar
projectSHO89
Check out the FAQs in the HVAC section.
There's noting about your SD that is particularly unique for the HVAC system.
Old Jun 3, 2009 | 09:31 PM
rem260man's Avatar
rem260man
Ac
Max AC and all is clean in front... I don't know about pressure. It can't be low on freon and work most of the time can it?
Old Jun 3, 2009 | 10:21 PM
dmd's Avatar
dmd
I had the same issue on 111-deg day once.... Now that was a hot day.
Does it do it often? Also define
hot.... Need to remember that TX hot is much different than Oregon hot..
Old Jun 4, 2009 | 01:34 PM
rem260man's Avatar
rem260man
Does it around 90. It has been getting worse. Started last year but would do it maybe once in a 250 mile trip. Now it will do it 3 times in a 25 mile trip.
Old Jun 4, 2009 | 02:02 PM
krewat's Avatar
krewat
It very well could be low on refrigerant. As the system pumps the refrigerant around, there is a low-pressure switch, and a high-pressure switch. Working too much, the low pressure side may drop below the low-pressure cutoff. Or, there's too much refrigerant and the high-pressure cutoff is kicking in.
Without pressure gauges and testing it when it's failing, you could throw new pressure cutouts on it, but that's wasting $'s in my opinion especially if you can't check how much refrigerant is in it by checking the operating pressures.
krewat's Avatar
krewat
Old Jun 4, 2009 | 07:15 PM
high ho silver's Avatar
high ho silver
I bought a nice set of gauges from Harbour Freight on sale for 39.99...it's much easier to use than the cheap single gauge that you have to switch from low to high to check.
Old Jun 5, 2009 | 06:28 AM
rem260man's Avatar
rem260man
What should the pressures be?
Old Jun 5, 2009 | 08:16 AM
SpringerPop's Avatar
SpringerPop
Since it cools good when it works, your refrigerant is likely OK. You have symptoms of the clutch air gap having worn too wide.
The quickest, easiest check to make is located in this thread:
https://www.ford-trucks.com/forums/5...ml#post4464164
It won't cost you anything to try, and it fixed mine for four years, now.
Pop
Old Jun 5, 2009 | 09:28 AM
Bear River's Avatar
Bear River
Former ******
wAht the pressures should be requires more knowledge of AC systems. As the ambient temperatures change, so does the pressure within the system. There are charts that tell you the target pressures for a given temperature.
Old Jun 5, 2009 | 12:34 PM
krewat's Avatar
krewat
Pop, thanks for that, I totally forgot about the air-gap symptoms of when it's really hot, it stops working.
THANKS! Rep points (if I can).
azchris
6.7L Power Stroke Diesel
13
May 7, 2015 06:22 AM
GA Quackhead
Jun 27, 2011 10:05 AM
ricg
Aug 25, 2010 03:43 PM
ilbigmike
Jun 25, 2009 12:55 AM
