climate control - A/C problem
Old Mar 18, 2015 | 04:30 PM
azchris's Avatar
azchris
Here is the issue i am having. 2011 F-350 King ranch with all bells and whistles. In Arizona now we are in the season that the weather is cold in the AM and sometimes hot enough in the late afternoon to need the A/C in the truck. with the settings on Auto which i normally do, and the external temp reading in the 80s, and the internal thermostat set at 70 or lower, the A/C compressor will not engage and allow for cooling the cab of the truck. But sometimes it will work just fine. I am assuming there is a temp sensor for cabin temperature. does anyone know where that is located. or will i have to change out the entire Climate Control Module. I would take it in to have it checked out but it is an intermittent problem, and i cant not have my truck for a couple of days while they try and figure it out.
Old Mar 18, 2015 | 08:54 PM
Chad149's Avatar
Chad149
Could be a bit low on freon. Need to hook up some gauges to see what it's doing and take it from there.
Old Mar 18, 2015 | 09:40 PM
MPD56's Avatar
MPD56
I believe that all the sensors are in the duct where the blend doors are. Does the AC work in manual?
Old Mar 19, 2015 | 01:37 AM
Dakster's Avatar
Dakster
Before you do anything. Reboot the computers in the truck... I use Forscan and do a diagnostic. You need to do the one where you hear the a/c doors open and close. Then see if it doesn't work.
My 2011 freaked out on me driving from Florida to Alaska and in the last part of Canada in the middle of nowhere, I couldn't get any air to flow out - whether in heat mode or cold. Manual or auto. Once I rebooted the computers with this diagnostic everything worked and it didn't do it again until I traded it on the truck in my signature.
If that fails, start the diagnostics.
Old Mar 19, 2015 | 05:59 AM
ruschejj's Avatar
ruschejj
I had a 2008 and a 2011 truck and both needed a shot of freon every year. I'm assuming that next year I will need to hit the 2015 I have now.
I don't know why and I've never worried about it, just top the system off and keep driving...
Maybe not your issue but still, I'd top it off. The freon bottles at the parts store have gauges on them now so if you follow the instructions and watch the gauge it's pretty simple.
If I were in your position I would do as dak suggests.
Old Mar 19, 2015 | 06:01 AM
capt caper's Avatar
capt caper
Our a/c condensers leak like the radiators. They are in the dash area and the dash has to come out. $1300 at Ford seems average. Have that checked first. Ask me how I know.
Old Mar 19, 2015 | 07:56 AM
Gints's Avatar
Gints
Cabin temp sensor is behind little louvers by your right knee.
Old Mar 19, 2015 | 08:44 AM
69cj's Avatar
69cj
Bingo, we have a winner. Give that man a cigar.
Old Mar 19, 2015 | 09:11 AM
azchris's Avatar
azchris
When it is acting up, the manual overrides does not work. Dakster, how do i reboot the computers, is that just a pull the battery cables and reattach after a few minutes?
AZChris
Old Mar 19, 2015 | 01:42 PM
Chad149's Avatar
Chad149
Condensers are located up in the front cooling system/radiator area, the evaporator is under the dash.
But yes, there was a bad run of evaporators in 2011 models garnered from reports here on fte.
Old Mar 19, 2015 | 04:07 PM
Dakster's Avatar
Dakster
I used an OBDII Bluetooth Reader and Forescan. The reader was $5 shipped from amazon, and forescan was free...
JUST resetting CODES did NOT WORK....
I don't know any other way to do it - Forescan has some diagnostic procedures that "reboot" the computer as part of the test. One of the diagnostic programs will test the HVAC system too.
Old Apr 22, 2015 | 06:30 PM
azchris's Avatar
azchris
A/C issue - culprit found
Had a friend with a computer scanner find that it is the Evap Temp sensor is at fault. Intermittent fault. He cleared it but now the research to see how to replace. and what the part number is. Any of our tech friends out there have a service procedure on how to fix. What little i have figured out is the Dash has to come out. Trying to decide if i want to do it my self or just pay to have it done.
Old Apr 23, 2015 | 01:04 AM
O&G's Avatar
O&G
Mine just came out of the shop for the same reason. I had the condenser replaced due to a leak and they told me the 2011 models had an issue with the climate control sensor. He said just don't run it in auto mode and it will be fine. It was another $600 to replace the sensor, etc...
Old May 7, 2015 | 06:22 AM
99FORD EXPY.'s Avatar
99FORD EXPY.
i had the same issue last summer , ford dealer said to me that they reset the HVAC system. that worked great for that summer . now its doing it again ...
bakon
2009 - 2014 F150
Jul 30, 2014 02:16 PM
polaris192
Apr 3, 2011 02:39 PM
CentralCoaster
2004 - 2008 F150
17
Mar 2, 2008 09:13 AM
Mike SVOR
6.4L Power Stroke Diesel
Sep 22, 2007 06:24 PM
nanuke1
Jul 16, 2004 03:53 PM
