Todo list......
Old Jun 6, 2009 | 04:41 PM
  #46
Visseroth's Avatar
Visseroth
LOL, well not yet
Yea, my wheel shows some wear so yea I'm putting a new WW in it, a new E99 WW
Old Jun 7, 2009 | 04:12 AM
  #47
Visseroth's Avatar
Visseroth
Mod Todo List Update
Just updating my list. Maybe someone will find this useful for their vehicle, maybe some newbie will use this list for their vehicle. None the less here it is
CCV Mod
WW Replacement
IDM Mod
GPR LED Indicator
Intercooler Noise Dampener Delete
Higher Pressure Fuel Pressure Spring
203° T Stat
Billet T Stat Housing
Coolant Filtration Kit
Max AC Assist Mod
On Board Air compressor w/tank
Train Horn
'08 Diff Cover Upgrade
PCM replacement
Swamp's IDM Mod
4" SS Exhaust
DP-Tuner
17* HPOP
Better fuel filtration/air removal system
Fuel bowl delete
In tank Filter delete
220 Amp Alternator
Turbo
Pedestal
Up-Pipes
6.0 Intercooler
3" Spider
3" Plenums
Hood scoop air intake
Valair clutch w/Kevlar idler bearing
Deer Slayer Bumper
Old Jun 7, 2009 | 11:58 AM
  #48
gasgrunt88's Avatar
gasgrunt88
What is the intercooler noise dampener delete and the higher pressure fuel pressure spring?
Old Jun 7, 2009 | 03:46 PM
  #49
Visseroth's Avatar
Visseroth
I found information some where that if you replace the spring with a slightly more stout spring or shim the fuel pressure spring then you can increase the fuel pressure by about 10 to 20 lbs, there by increasing torque and hp.
Intercooler Noise Dampener Delete is just removing th aluminum foil from the intercooler pipes. Maybe it would sound better if I put it that way.
Old Jun 7, 2009 | 08:03 PM
  #50
gasgrunt88's Avatar
gasgrunt88
Intercooler Noise Dampener Delete sounds pretty delete. Sounds much more legit than "foil delete"
Old Jun 7, 2009 | 11:10 PM
  #51
Visseroth's Avatar
Visseroth
lol, Well I'll change it when I come up with something else
Old Jun 7, 2009 | 11:30 PM
  #52
Visseroth's Avatar
Visseroth
CCV Mod
WW Replacement
IDM Mod
GPR LED Indicator
Intercooler Foil Noise Dampener Delete
203° T Stat
Max AC Assist Mod
Train Horn
PCM replacement
Swamp's IDM Mod
4" SS Exhaust
DP-Tuner
Modded 17° HPOP From Terminator Engineering
Fuel bowl delete
220 Amp Alternator
Turbo
Pedestal
Up-Pipes
6.0 Intercooler
3" Spider
3" Plenums
Deer Slayer Bumper
More guages (Boost, Pyrometer, Coolant Temp, Oil Temp, Trans Temp, Amp Draw, Voltage)
Old Jun 7, 2009 | 11:53 PM
  #53
gasgrunt88's Avatar
gasgrunt88
That was supposed to be "...sounds pretty technical." I had a brain fart and for some reason typed delete lol.
Old Jun 8, 2009 | 12:17 AM
  #54
Visseroth's Avatar
Visseroth
Yea, my wife says I'm not aloud to use the word fart, LOL, how about cranial flatulation?
Old Jun 8, 2009 | 01:50 AM
  #55
orng1's Avatar
orng1
Flatulance is appropriate.
Old Jun 8, 2009 | 09:36 AM
  #56
superduty4x4's Avatar
superduty4x4
You better get a fuel PSI gauge, and don't let it get above 70lbs IIRC.
Old Jun 8, 2009 | 10:47 AM
  #57
big poppa's Avatar
big poppa
This why I didn't do my FP mod, on the wish list. Shoot a bunny is more appropiate around kids...or is it
Old Jun 8, 2009 | 10:57 AM
  #58
03_PSD's Avatar
03_PSD
whats optimal fuel pressure? i got my gauge installed this weekend and its right at 60.
Old Jun 8, 2009 | 12:35 PM
  #59
Visseroth's Avatar
Visseroth
Yea, probably need to hold off on that one as well. I should add fuel pressure gauge to my gauge list.
Old Jun 8, 2009 | 12:37 PM
  #60
superduty4x4
Originally Posted by 03_psd
whats optimal fuel pressure? I got my gauge installed this weekend and its right at 60.
65-68 iirc.
