Doesn't sound hard. Sounds to me to be 1 positive wire from your 12v LED to the GP relay and 1 wire to a ground in the cab.
Correct me if I'm wrong.
Anyhow, list update.......... Oh, and I meant to put 4" Exhaust system on there but apparently forgot, it was only about midnight or 2 in the morning when I wrote it!!!
CCV Mod
WW Replacement
IDM Mod
GPR LED Indicator
Intercooler Noise Dampener Delete
Higher Pressure Fuel Pressure Spring
Coolant Filtration Kit
'08 Diff Cover Upgrade
PCM replacement
4" SS Exhaust
DP-Tuner
17* HPOP
Better fuel filtration/air removal system
Fuel bowl delete
In tank Filter delete
220 Amp Alternator
Turbo
Pedestal
Up-Pipes
6.0 Intercooler
3" Spider
3" Plenums
Hood scoop air intake
Valair clutch w/Kevlar idler bearing
Does anyone have any further suggestions, crazy ideas, thoughts, anything, I am all ears!!!
I'm actually getting close to having a full work weekend on my pile... I want to find out about modding my stock track bar to be adjustable, then I might just take a weekend and get all my parts installed. I might even be getting a new turbo...
Good to hear that you'll be getting some stuff done. New to you turbo huh???
lol, well bud you let me know if you need a hand. I'll make some time to give you a hand if you'd like some.
So what's this adjustable track bar thing?
Lets you make sure the axle is centered under the truck after doing a lift/level kit. Not necessary with a level kit, but needed for a lift.
So what do you think Chase? Maybe we should all meet at your place? I really don't have that much to do, at least not at the moment. Not tell I spend some big bucks.
Can't really do it at my place unless you want to do it in the drive way and I don't have a decent set of tools. I have enough to get by.
Any thoughts?
Any more suggestions for my todo list or should I new print it and put it on the wall for my wife to see so she can tell me to get multiple jobs
Maybe she'll use the list to get me new toys to calm my PMS?
