ABS problem with 2003 expedition
Old Jun 1, 2009 | 10:41 PM
buymeford's Avatar
buymeford
I am experiencing so issues with the abs light coming and the truck`s ABS system acting up all the time.
I did a sear and seems like the first gen expy are notoriour for blowing the rear speed sensor on the diff.
Same deal with the IRS equipe 03up expy? They have a different rear end so I am curous to find out some info about it.
Old Jun 2, 2009 | 08:26 AM
c_hohensee's Avatar
c_hohensee
I think on the irs equiped expy's there was a seperate speed sensor for each rear wheel. It could be a speed sensor, but the best thing to do (unless someone has a specific problem and solution common to that year) is find someone with an abs scan tool.
Old Jun 3, 2009 | 03:45 AM
Red-navi-916's Avatar
Red-navi-916
if you have after market wheels that should solve the ABS light broblem..the system reads that the wheels are not factory from the maker and their heavier and bigger and the light will stay on.if you have stock wheels then ur s.o.l lol
Old Jun 3, 2009 | 11:17 AM
buymeford's Avatar
buymeford
Wheels are stock.
Old Jun 3, 2009 | 12:23 PM
bumparker's Avatar
bumparker
On the front of an '03 the sensor is part of the hub assembly. I have not replaced anything on the rear, but if there is a hub I would assume the sensor is integrated. These hubs are not cheap.
I think there is a speed sensor on the transmission, easy to change, not sure if it is integrated into the ABS system.
Old Oct 16, 2009 | 09:57 PM
TexFinn's Avatar
TexFinn
No kidding!
The ABS light on my wife's Expedition had been going on and off recently and I decided to check the front brakes, just in case. Glad I did!
My wife said she has been hearing some noise from the front recently. Especially when turning right. The hub on the driver's side had about 1/2" play in every direction. Damn!!!
I guess it had also messed up the ABS sensor, too. Bought a new hub from O'Reilly's ($270... ), put it on (together with new pads and rotors) and now it's like new again.
Turned out to be an expensive brake job, but I'm glad I did as the hub wouldn't have lasted for too long anymore sending the driver's side wheel on its own course leaving my wife with only three wheels. Not a nice scenario...
Old Oct 17, 2009 | 02:47 PM
alloro's Avatar
alloro
No, not a nice scenario...unless of course you have a good life insurance policy.
Old Oct 17, 2009 | 09:09 PM
TexFinn's Avatar
TexFinn
Very true.
fast58
Jan 27, 2015 11:11 PM
juang316
19
Feb 28, 2014 09:48 PM
dclowrider
Nov 1, 2013 01:41 PM
Drewsc
112
Sep 12, 2013 09:03 PM
RUSTY50F1
28
Oct 19, 2007 05:58 PM
