04 engine swap
Old Jun 1, 2009 | 07:39 AM
toolman401's Avatar
toolman401
04 engine swap
Hi Guys
I have 04 4.6L auto, 2wd F150 about 6 months ago bend a valve and cracked a head had them replaced. now when i start the truck i get white smoke from the tail pipe and a anti freeze smell. thinking about getting rid of this dog and dropping in a 5.2L. what does it intail
Love the truck just what to stop have problems with this motor.
Old Jun 1, 2009 | 09:55 PM
Oldguy4's Avatar
Oldguy4
Just finished reading an article in Classic Trucks magazine, where they are trying to make a 4.6 work in a '68 bump side. It's very difficult. I would strongly suggest you just get your hands on a rebuilt 4.6 and go with that. These days, with all the electronic controled engines we have it's just too much trouble to change what the rig came with. JMO.
Old Jun 1, 2009 | 10:04 PM
Ryan50hrl's Avatar
Ryan50hrl
1. There are no 5.2's......it would be a 5.4....
2. If you could find a whole F-150 thats been wrecked to use as a donor vehicle its not that bad, but without the wiring harness, pcm, ect.....it's gunna be expensive and hard....
Old Jun 1, 2009 | 10:05 PM
Ryan50hrl's Avatar
Ryan50hrl
See....now there are stand alone harnesses available to run modern engines in old vehicles.....it shouldn't be that hard
Old Jun 2, 2009 | 02:16 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I really recommend you buy an entire donor truck like Ryan said.
you'll need the entire motor, accessories, PCM, wiring harness, the transmission, the rear axle, motor mounts
you can mix n' match some stuff...but if you're going to put a 5.4 into the truck, do it right and match the stuff up properly.
if you cannot do a donor truck...it's probably in your best interests to just swap in another 4.6 2v
parasail
Aug 8, 2021 07:14 PM
6.0superduty
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jan 12, 2016 02:01 PM
Crabby144
2004 - 2008 F150
Oct 20, 2014 10:54 PM
toolman401
1997 - 2003 F150
Jun 1, 2009 10:48 PM
samia
1997 - 2003 F150
Jan 25, 2004 08:38 PM
