vacuum pump - replacement or rebuild?
Old Jun 11, 2009 | 07:03 AM
BlueMule's Avatar
BlueMule
Originally Posted by fishmanndotcom
are you supposed to oil or grease these things up before using them? i have read you are supposed to but i havent found an official procedure
-cutts-
I've never seen anything official either, but there is a bolt/plug in the center of the rear that you can remove and add a bit of oil/grease to the rear bearing.
Old Jun 11, 2009 | 09:34 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Does anybody has the International part # of this pump? and any has used one from IH?
Old Jun 11, 2009 | 01:19 PM
BlueMule's Avatar
BlueMule
Jose
I'm not sure that any of the T444E's use a vacuum pump. I've only looked at a couple of them and they had an engine mounted compressor for air brakes.
Old Jun 11, 2009 | 01:25 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Originally Posted by BlueMule
Jose
Thanks Rod, I really want to know if there is a cross number between the FORD and IH in the same vacuum pump for our OBS trucks? I have a IH dealer in town and thougth I could buy one from them for my truck.
66v8baby
Nov 17, 2016 09:44 AM
DattMavis
Jan 19, 2016 05:05 PM
marine09
Jan 14, 2016 12:47 PM
CapeFear562
Large Truck
Apr 11, 2015 03:39 PM
HangGlider
Jun 20, 2003 08:06 PM
