No heat.
Old Jan 14, 2016 | 11:10 AM
marine09's Avatar
marine09
No heat.
I have a 77 f150 with the 351m. The guy I bought it from in Hawaii ripped out the the heater hoses and plugged off the water outlet nipple and the water pump nipple. I bought new hoses and hooked them up to the nipples and replaced the heater core. I've been burping the system for a while now and all I can get is room temperature air. It's 30° out and I desperately need my heater. Lol. Any suggestions?
Old Jan 14, 2016 | 11:12 AM
Tedster9's Avatar
Tedster9
It's 30F. In Hawaii. Your profile sez that's where you're at.
Where are you at in Hawaii, on top of Mauna Kea?
OK, Is there a thermostat installed?
Old Jan 14, 2016 | 11:14 AM
Jeremy Kamutzki's Avatar
Jeremy Kamutzki
Sounds dumb, but did the heater core come with plugs that may still be in the passages?
Also, is it possible that the hoses are blocked off with a plate as well as a plug? Do you get coolant through the hoses? Do you maybe have the hoses hooked up backward?
When the truck gets up to temperature, do the heater hoses feel hot?
Old Jan 14, 2016 | 11:17 AM
marine09's Avatar
marine09
When I bought the heater core, it had caps on the ends of the nipples. I removed those. Neither of the heater hoses have a block off plate. Yes both hoses feel hot. Not extremely hot but hotter than when I first started burping the system
Old Jan 14, 2016 | 12:14 PM
KidWithTheLoudFord's Avatar
KidWithTheLoudFord
The flap that directs the air either past the heater core or around it might not be all the way closed off to prevent all the air from passing the heater core. Just a thought?
Old Jan 14, 2016 | 12:28 PM
marine09's Avatar
marine09
I'm no longer in Hawaii. I'm in north Idaho. And I'll have to look at that lil door
Old Jan 14, 2016 | 12:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350 & 1978/79 Bronco fresh air heater. Without factory installed integral A/C
Old Jan 14, 2016 | 12:47 PM
marine09's Avatar
marine09
I have been looking all over for that diagram! Thx
dss90c
Dec 19, 2019 05:17 AM
mdbbrown
Dec 29, 2012 11:23 AM
bighighboy77
Dec 23, 2007 02:17 PM
maddog72
Jan 23, 2005 06:02 AM
77'F-150Mudder
17
Dec 7, 2003 02:18 AM
