Problems with getting truck to start
Old May 31, 2009 | 07:44 AM
ReggieR's Avatar
ReggieR
Question Problems with getting truck to start
Weird. My truck just began to not start sometimes. If I try to crank it up in the morning it won't start but 6-7 hours later it will start and after I park it for the night it does the same thing the next day. What could be the problem?
Old May 31, 2009 | 07:50 AM
bismic's Avatar
bismic
Welcome to FTE ReggieR.
Please post some information on your truck if you don't mind. It will help you get the proper help (year model, and mods, mileage, most recent fluid and filter change info, etc)
Old May 31, 2009 | 08:09 AM
ReggieR's Avatar
ReggieR
Truck won't start
My truck will start in the late evenings when it is hot but will not start in the mornings when it is cool. What could be the problem?
SPECS:
2004 F350 Dually
Diesel Powerstroke
15-40 motor oil
ford motor craft coolant
oil & filter change in april 09
168,000 miles
Old May 31, 2009 | 08:11 AM
Maxium4x4's Avatar
Maxium4x4
From your profile the truck is a 2004, we have a familiar situation in this thread if you want to read through. Click here
Old May 31, 2009 | 08:49 AM
ReggieR's Avatar
ReggieR
Thanks Maxium 4x4
I have had the crank sensor replaced and EGR valve replaced. I will replace the connecting harness and see if that will fix it.
Old May 31, 2009 | 04:11 PM
Maxium4x4's Avatar
Maxium4x4
If you think it is the ICP as in the thread I mentioned, just unplug it and see if it will start.
Old Jun 6, 2009 | 01:00 PM
ReggieR's Avatar
ReggieR
Still can't find problem with truck. Changed everything. Could it be the glowplug? What happens if the glow plug is not functioning? Could this cause the truck to not start?
Old Jun 6, 2009 | 01:19 PM
bismic's Avatar
bismic
No start could be:
injector o-ring failure
air in the fuel
no fuel flow
bad Fuel Injection Control Module (FICM)
high pressure oil rail o-ring failure
high pressure oil stand pipe o-ring failure or the pipe itself
the high pressure oil pump (HPOP) stc fitting (if so equipped)
the high pressure oil branch tube
a stuck or bad injection pressure regulator (ipr)
a weak HPOP pump, or
the injection pressure control (ipc) sensor
a bad PCM (computer)
wire chaffing on key components.
I am sure there are more potential causes.
Regarding the fuel flow potential - do you use Motorcraft fuel filters and are you sure you do not have some air in the system? Is the upper fuel filter bowl filling up properly when cranking?
FYI - in the high pressure oil system you must develop enough oil pressure (500 psig), AND the ICP needs to detect it, or it will not start.
Your issue seems to be that it starts sometimes and not others.
Sometimes a high pressure oil leak will cause a no-start when HOT. Then it will start cold. This does not sound like your problem.
Can you take it somewhere to get the codes read (or borrow a code reader)?
We really need more info to help (IMHO).
Old Jun 6, 2009 | 01:29 PM
bismic's Avatar
bismic
You might want to read these over and inspect for wiring problems:
<TABLE style="WIDTH: 568pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=757 x:str><COLGROUP><COL style="WIDTH: 568pt; mso-width-source: userset; mso-width-alt: 27684" width=757><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 568pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=17 width=757>Wire Chaffing Locations</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 568pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=757>http://www.thedieselgarage.com/forums/attachment.php?attachmentid=17301&d=1208412696</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 568pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=757>http://www.forddoctorsdts.com/articles/article-05-11.php</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 568pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=757><TABLE style="WIDTH: 568pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=757 x:str><COLGROUP><COL style="WIDTH: 568pt; mso-width-source: userset; mso-width-alt: 27684" width=757><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 568pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=757>http://www.forddoctorsdts.com/articles/article-05-13.php</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Old Jun 6, 2009 | 03:30 PM
bismic's Avatar
bismic
ReggieR -
This is a fairly detailed video on a hard-start / no-start condition:
mms://multimedia.ford.com/seopts/Tech_3_256klarge.wmv
Old Jun 6, 2009 | 04:49 PM
bismic's Avatar
bismic
Hard-Start / No-Start Diagnostic Checklist:
http://www.fordtechservice.dealercon...iagnostic2.pdf
