Need help with 6.0L
Old May 27, 2009 | 06:09 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Need help with 6.0L
Well just got back from a 500 mile round trip on monday. Tuesday the truck ran fine, and now this morning it's not starting. I did this twice up on our trip but it fixed it self when you turn the key off and on. Any Ideas?
Thanks
Nick
Old May 27, 2009 | 07:04 PM
Maxium4x4's Avatar
Maxium4x4
Try unplugging your ICP sensor and let it default to see if the engine runs.
Old May 27, 2009 | 07:39 PM
weekendwarriorfsw32
Master of Strokes
Thanks but where is the located and how would this help?
Old May 27, 2009 | 08:23 PM
Kep4's Avatar
Kep4
Jäger
What's a 6. blower?
Old May 27, 2009 | 08:29 PM
Maxium4x4's Avatar
Maxium4x4
2004 model year the ICP was moved from under the turbo to the right front valve cover. Just want you to unplug it and the pressure reading will default.
Old May 27, 2009 | 08:32 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by Kep4
What's a 6. blower?
I think it's a play on 6."blow"
Old May 27, 2009 | 08:38 PM
bismic's Avatar
bismic
The ICP (Injection Control Pressure) sensor needs to read 500 psig to fire the injectors. If it fails low, you potentially will crank, but not start. By unhooking it, your computer detects that it is not present and goes to a default control strategy that should allow your truck to start if the ICP sensor is truly what has failed. If you are having problems with your LPOP (low pressure oil pump) or HPOP (high pressure oil pump), disconnecting the ICP sensor will not make any difference.
Can you tell us more about your truck. Have you changed fuel filters recently? Does it have a strong crank but just not start? Are you sure your batteries are good? I always load test my batteries as the very first troubleshooting task when I have a no-start condition.
The second thing to check is to make sure you do not have loose fuel filter caps, cracked caps, or failed o-rings. Then make sure your secondary fuel filter bowl is filling up.
There are many things that can cause a no-start. Need more info to really troubleshoot, but you have a few easy things to check.
Old May 27, 2009 | 08:43 PM
brickie's Avatar
brickie
Originally Posted by bismic
The ICP (Injection Control Pressure) sensor needs to read 500 psig to fire the injectors. If it fails low, you will crank but not start. By unhooking it, your computer detects that it is not present and goes to a default control strategy that should allow your truck to start if the ICP sensor is truly what has failed. If you are having problems with your LPOP (low pressure oil pump) or HPOP (high pressure oil pump), disconnecting the ICP sensor will not make any difference.
The second thing to check is to make sure you do not have loose fuel filter caps, cracked caps, or failed o-rings. Then make sure your secondary fuel filer bowl is filling up.
Great post Bismic,I would rep you if I could.
Old May 28, 2009 | 01:09 AM
weekendwarriorfsw32
Master of Strokes
No to be stupid but there are a lot of plugs in that area. Does any one have a pic of one?
Old May 28, 2009 | 03:26 AM
Maxium4x4's Avatar
Maxium4x4
ICP click here
Old May 28, 2009 | 06:28 PM
weekendwarriorfsw32
Master of Strokes
Alright I found out it's my ICP Sensor that went out. Does any one know where to get them cheap?
Thanks
Nick
Old May 28, 2009 | 06:33 PM
Maxium4x4's Avatar
Maxium4x4
I wouldn't worry about price at this point, head for the dealer and pick one up. Make sure to inspect the wiring harness at the plug also.
Old May 28, 2009 | 06:41 PM
weekendwarriorfsw32
Master of Strokes
They want 160 for a little sensor? I don't feel right spending that much on a little part.
Old May 28, 2009 | 07:08 PM
Maxium4x4's Avatar
Maxium4x4
Here is the ICP part number 4C3Z9F838AB
Try your local International dealer, the 6.0L engine is a VT365 IH or use Google search to find a deal from someone else like Ebay if you want to wait and have it shipped to your address. FTE Parts Guy
Sometimes spending $30 in fuel running between parts stores to save $5 doesn't seem rational.
Old May 28, 2009 | 08:29 PM
pjwoolw's Avatar
pjwoolw
Parts guy had em for $95 last year. Send him a PM.
