154 hp 5.4l?
Old May 30, 2009 | 08:37 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
yeah, there is nothing really bad about owning/operating a FFV
btw, the mileage stuff I put up above...that was on 87 octane. the exact same driving with E-85 is MUCH MUCH WORSE. E-85 is a crock of crap.
at 70 mph with E-85 I got 14 mpg highway only. 10 mpg city with E-85
the stuff sucks. even though E-85 is so much cheaper at the pump, do the math.
Once you figure the lower MPG's and the more frequent gas tank fill-ups, the E-85 quickly matches, and sometimes exceeds what you'll pay for 87 octane
I personally barely broke even when running E-85. The MPG difference is so bad, that it just isn't worth it.
also, when you run E-85, you have to follow a High Maintenance Schedule. Oil changes are more frequent and more maintenance is required
Old May 30, 2009 | 08:41 PM
Greg B's Avatar
Greg B
It has to be a misprint on that sight. 5.4L flex fuel is the exact same engine except for the fuel system. They have a different and bigger pump, the e-85 fuel sensor, and fuel injectors and seals that can withstand the corrosiveness of ethonol. Otherwise the engines are the same as is the reg. unleaded fuel map strategy in the PCM.
Old May 30, 2009 | 08:43 PM
30coupe's Avatar
30coupe
Thanks, Tylus! That is EXACTLY what I expected. The whole ethanol in motor vehicles thing is a gigantic farce perpetrated on us by our government. I am so disgusted with I can't express it in words. Under the current regime, we soon may not be able to express it at all .
youknowitdadio
Jun 19, 2017 07:39 PM
cowboybootlegger
18
Sep 3, 2015 08:39 PM
73cntry
Modular V8 (4.6L, 5.4L)
May 14, 2011 12:13 AM
RadRick
6.2L V8
19
Jan 2, 2011 10:59 PM
Jerm
18
Jul 15, 2002 06:55 AM
