Center Bearing/Support
Old May 18, 2002 | 10:36 AM
SteveFE's Avatar
SteveFE
I'm about to install a new center bearing and support on my '71 F250
Upon removing the old bearing/support I noticed that the bearing was the same on both sides meaning it wouldn't have mattered which way you installed it. The new support only has the large rubber lip on one side. Does it matter which way this one goes in? On the carton for the new bearing/support it shows two figures for installation and the support being installed with the lip goint either towards the trans or towards the rear. I would be inclined to install it towards the trans as it will be far easier pressing it on this way.
Old May 20, 2002 | 12:02 AM
AZ4x4f150's Avatar
AZ4x4f150
I usaully install the new bearing with the bearing towards the trans and the rubber towards the axle unless stated to do something else
Old May 20, 2002 | 07:36 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Mercmeister
18
Feb 3, 2014 10:11 PM
plywood50
2004 - 2008 F150
Sep 14, 2010 10:33 PM
mookie980g
Modular V10 (6.8l)
Nov 20, 2009 05:08 PM
Steve Straus
May 19, 2008 06:41 PM
