91 E4OD torque converter question.
Old May 17, 2002 | 05:45 PM
Phrappster's Avatar
Phrappster
Hi,
I've read the archived posts about the shuddering/vibration problem common with the e4od and when my van(91 e250) starts shuddering I lightly touch the pedal and it stops.(as someone posted, that's the computer dis-engaging the converter).
Someone else said that most times if you drain thr torque converter it fixes the slipping problem.
O.K., here's what I did: Removed the rubber plug under the converter, turned the engine until the bolt(drain plug) was facing down, drained what I thought was the torque converter but the transmission's fluid drained out as well! I thought that wouldn't happen. Was that drain for the converter? I hope not cause that means I have to change it cause a fluid change didn't fix the slipping problem.
thanks,
Rod
Old May 19, 2002 | 06:22 AM
capt scott's Avatar
capt scott
boy, have i been living this scene, with an 89 f350 and the e4od. in theory, draining at the converter could siphon the fluid out of the pan. in reality, what everybody meant was that you should be changeing the fluid in the tranny completely!!!!! not just in the pan or in the converter. only changeing part of the fluid most often does not yield the desired results!(old fluid left in the pan or converter contaminates and dilutes the new fluid!) i always recomend changeing the filter along with the fluid and also adding a synthetic additive to help the shuddering.
Old May 19, 2002 | 01:09 PM
Phrappster's Avatar
Phrappster
I was wondering about that!
I changed the fluid and filter last month, then drained the converter this month! But contamination is my last thread to hold on to so I'll do them both at once this time.
Any suggestions on an additive??
Old May 19, 2002 | 01:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
[updated:LAST EDITED ON 19-May-02 AT 02:59 PM (EST)]You should always drain the torque converter and transmission pan at the same time. They share fluid, so only draining one of them mixes old and new fluids. You are far better to have all new fluid.
Use a MERCON rated fluid. Synthetics are better, and I think Mobil 1 synthetic ATF is the best.
There are no additives that I would even consider installing in one of my transmissions!
Mark
Old May 19, 2002 | 03:09 PM
Phrappster's Avatar
Phrappster
Allright, thanks.
I'll try the synthetic, it barley slips so that might just do it.
I couldn't think of a way to re-fill the converter so I just idled her for a few minutes then went through the gears.
I hope this works,
thanks for the reply.
Old May 20, 2002 | 07:36 AM
Mark Kovalsky
The only way to refill the torque converter is to fill the pan and idle the engine.
Mark
Old May 20, 2002 | 05:36 PM
kennethl6's Avatar
kennethl6
quaddriver
20
Nov 1, 2011 02:24 PM
Blackbronco
Dec 4, 2010 05:49 PM
05ExcursionLTD
Jun 19, 2009 07:15 AM
Uglyhat
Oct 24, 2005 05:32 PM
TallPaul
Jun 19, 2004 01:52 PM
