Driveshaft Bearing Support
Greetings! -
Please reference the following link for the part in question:
I am rebuilding a 1966 Ford F100 and plan on replacing this bearing support. I have removed the drive shaft My question is, how do you remove the old bearing support and install the new one?
Thank You!
Dan M.
Thank You!
Dan M.
1966 Ford F100 Bearing Support
Greetings! -
Please reference the following link for the part in question:I am rebuilding a 1966 Ford F100 and plan on replacing this bearing support. I have removed the drive shaft My question is, how do you remove the old bearing support and install the new one?
Thank You!
Dan M.
Thank You!
Dan M.
Does anyone have an exploded view of the splined driveshaft and bearing support for a 1966 Ford F100 2-wheel drive? After cleaning the gunk off of the splines, I was able to remove the spline cup and star washer. But there is a metal donut that needs to be removed from the splined shaft before the bearing can be removed. Any help will be appreicated.
Thank You!
Dan M.
No zerk fitting on the bearing, it's located on the slip yoke.
Left: This is the only pic in the 1964/72 catalog / Right: Same pic in 1973/79 catalog, different applications.
Beginning 1974, FoMoCo only sold the bearing as part of a kit.
D9TZ-4800-A (replaced D4TZ-4800-A) .. Driveshaft Center Support Kit-Includes bearing, shims, brackets, rubber support / Available from Ford.
Applications: 1961/79 F100/250 & some F350's.
The splines need to be greased, but the bearing is a sealed unit.
Added 1973/79 pic...same as 1964/72 except it now includes F100 that was missing from earlier pic.
3) C5TZ-4635-F .. U-Joint-Use with 2 piece Driveshaft (front/center/rear) / Spicer/Dana p/n: 210392-X / 2 cups are 1310, 2 cups are 1330 / Obsolete - Available from autoparts stores
1965/79 F100 & 1975/79 F150.
I have a question about the "hanger bearing" if that's what is being talked about. There is a zirc on the spline sleeve "slip yoke" on the driveshaft. But the bearing itself isn't sealed. Thought I read somewhere that this actually should have chassis grease applied, though can't remember seeing it done either. Keep some water and.stuff out. Been meaning to do this. Never seen a good one yet on every truck I have bought with any miles on it. The rubber surround turns to Bakelite too after a while too. Will smooth things and quiet a bit, saves wear and tear. I kept everything indexed the same when I replaced this and the balance is much improved with new bearing and universals, etc. good maintenance on these rigs.
At this point, I would cut the rubber off the outside, then spray some penetrating oil onto the remaining metal ring that has seized onto the spline. Then using a hammer and large punch, place a few taps around the metal ring, hopefully causing it to come loose. Some light heat from a propane torch may be in order as well; but being careful not to use too much heat - I wouldn't want to take any temper out of the splines.....
BarnieTrk
BarnieTrk
