1978 - 1996 Big Bronco
rim/tires sizes
Old May 28, 2009 | 10:44 AM
josh33's Avatar
josh33
rim/tires sizes
i have 32*11.5*R15 tires on these chrome rims. this guy has 35*12.5*R15 tires on his rim. i don't know how thick my rim is but it holds my 11.5 tire, would it hold his 12.5 tire? and would the 12.5 rim fit my tires, that are 11.5? its probably hard to understand sorry....thanks
josh
Old May 28, 2009 | 11:12 AM
skysoldiervn's Avatar
skysoldiervn
Smile Rim Sizes
Josh33, I don't know what size rims you have so its hard to be accurate. I have 33x12:50x15 on my Bronco. The rims are 10". This is a good fit. So a tire 12.50 should fit on a 10" wide rim. However, you could have a clearance issue with a 35" tall tire. Be sure to check it out. Also, what year is your Bronco.
Old May 28, 2009 | 11:55 AM
josh33's Avatar
josh33
ok thanks, i have a 1995 ford bronco. i have a 3" body lift, would i still have clearance issues?
Old May 29, 2009 | 08:14 PM
greystreak92's Avatar
greystreak92
You may not have clearance issues but you will have performance issues running 35's without re-gearing for them. Just going up to 33's will give you passing and hill-climbing power concerns... 35's are going to be worse.
Old May 30, 2009 | 03:14 PM
josh33's Avatar
josh33
how would i gear it?
Old May 30, 2009 | 03:40 PM
NASSTY's Avatar
NASSTY
4.56's would work good with 35's
Old May 30, 2009 | 05:28 PM
greystreak92
Agreed, swapping to 4.56:1 gear ratios in both axles would alleviate performance issues when going up in tire diameter by that much.
Luckyc1423
Nov 4, 2016 10:45 AM
Gear619
Mar 10, 2015 01:44 PM
Jus2shy
2009 - 2014 F150
May 5, 2013 10:14 PM
perryau1996
Jun 1, 2012 08:26 AM
JDpolaris96
Mar 8, 2012 03:00 PM
