It's really no big deal if you have cruise and tilt.
The pin is readily accessible once the wheel is removed. It only take about 15 minutes to swap the cylinder out including removing and re-installing the wheel if necessary.
How do you do it when you don't have the key? I bought a 2000 f150 basket case and there was a key in the ignition but when I turned the key off it would not turn back on.
You have to drill out the cylinder. That I've done a couple times too.
You have to be careful though or else you could mess up the whole column. Your best bet would be contact a lock smith and have them make you a new key.
