Sponsored by: Real Truck
5.4 Noisy pcv valve
Old May 27, 2009 | 04:24 PM
tandpr's Avatar
tandpr
5.4 Noisy pcv valve
I have a 2001 f-250 with a 5.4. IT has 115K on it. I heard a weard humming noise under the hood. It sounds like a very noisy fuel pump. I just purchased the truck and it has always made this noise since I had it. I got curious one day and started feeling around. The pcv valve vibrates like crazy. If you pull it out of the engine it still vibrates. IF you put your finger over the end of it the vibrating pretty much quits. The truck runs fine but you can hear the vibrating pcv from inside the cab. Is this normal?
Old May 27, 2009 | 06:24 PM
onephinesuperduty's Avatar
onephinesuperduty
mine did the same thing a while back. Just get yourself a new pcv valve for a coupla bucks and you should be done
Old May 27, 2009 | 06:57 PM
tandpr's Avatar
tandpr
Thanks. That was my idea but its always good to have a little reassurance. I love this site.
Old May 27, 2009 | 07:27 PM
aldridgec's Avatar
aldridgec
Common, ditto above, weird isn't it.
Old May 27, 2009 | 07:49 PM
tandpr's Avatar
tandpr
Ok how bout this.......anybody got noisy lifters on start up after setting overnight? I thought it was because I used 10W30 instead of 5W20 so I put 5W20 synthetic blend in it and it still does it. I don't know if it is the lifters but it sounds more like lifters than lower end(bearings) more of a light rattle than a deep clatter.
Old May 28, 2009 | 09:32 PM
high ho silver's Avatar
high ho silver
Make sure to get a plastic PCV valve (not the metal one) or it will make the same humming noise.
Old May 28, 2009 | 10:39 PM
aldridgec's Avatar
aldridgec
could be piston slap. if it goes away quickly or once it warms up. a lot of modern engines do this because of the composition of the pistons.
Old May 29, 2009 | 08:32 AM
SBastow's Avatar
SBastow
Plastic pcv valve? I just bought one from carquest all metal. Why would this matter?
Old May 31, 2009 | 05:30 AM
high ho silver
what you are hearing is the metalic sound of the metal plunger on the inside vibrating. When it is new there is no oil residue to quiten it. Get the plastic one from the dealer and you won't here it.
Old May 31, 2009 | 10:18 AM
aldridgec's Avatar
aldridgec
I would buy this except i've seen lots of the triton pcv valves that are original and plastic hum because they are just bad. I don't think it really matters if it's metal or plastic, if it's not operating right the vacuum draw through it will cause it to vibrate, usually due to deposit build up.
Old May 31, 2009 | 04:24 PM
high ho silver
Maybe so, but when I bought my truck 7 years ago, I changed the factory pcv valve just as a preventative thing along with the rest of the stuff I felt needed changing. The pcv valve made no noise until I replaced it with a metal one from Advance Auto. It drove me crazy until I put the original plastic one back in. No more noise.
Just trying to give the OP something to consider.
Old May 31, 2009 | 09:12 PM
aldridgec's Avatar
aldridgec
Interesting. Could have been defective vs just the metal. who knows. good to know tho
kjeffery
Jan 18, 2017 04:46 PM
Jco06
2009 - 2014 F150
18
Jun 12, 2016 10:15 AM
steve(ill)
2004 - 2008 F150
Feb 23, 2016 06:02 PM
556n9mm
Dec 18, 2015 10:11 AM
CurtSD
Modular V8 (4.6L, 5.4L)
Aug 26, 2014 04:17 PM
