Vibration while maintaining constant speed. 98 exed
Old Dec 15, 2015 | 06:52 PM
556n9mm's Avatar
556n9mm
Hello!
My Wifes Expedition started doing this 2 days ago. 1998 4x4 5.4L
While maintaining a constant speed with foot on the accelerator the entire truck vibrates, if you accelerate it stops, if you let off the gas it stops. It also has a rough idle. I repaired a cracked PCV valve hose yesterday (the one that connects to the back of the intake by the firewall) Didnt help, so I reset the ECM, thinking it would help, it didnt.
So its no longer has a CEL. Ive been driving it all over the place trying to get the CEL to pop again.
I'm really at a loss as to what this could be, basically I've replaced the entire suspension over the last 2 years and it has brand new tires (I only state this because everyone says its a suspension problem. its not)
Throttle position sensor or maybe more vacuum problems? Any help would be greatly appreciated!!!!!
Old Dec 15, 2015 | 07:40 PM
r2millers's Avatar
r2millers
Sounds lik a plug/cop problem.
Last time the plugs were changed?
Mine would throw a cel when accelerating hard with a misfire, helping to identify which cylinder.
Maybe a fuel filter needs changing? Last time it was replaced?
Still could be a vacuum leak, PCV elbow on the back passenger side.
Old Dec 15, 2015 | 08:22 PM
pdqford's Avatar
pdqford
U-joints ?
Old Dec 16, 2015 | 03:21 PM
alloro's Avatar
alloro
Have you pulled the driveshaft and inspected the u-joints, especially the front cardan joint?
Old Dec 17, 2015 | 09:59 PM
556n9mm's Avatar
556n9mm
Thanks guys, I was so beat when I posted this I had completely forgotten about it.
The previous owner was my brother in law, he did all the maintienence on it Ill shoot him a text when he get back.
Again thanks, Ill post what I find out.
Old Dec 18, 2015 | 10:11 AM
alloro's Avatar
alloro
Sometimes that can make family gathers a bit uncomfortable if things go drastically wrong with the vehicle.
NashvegasMatt
56
Dec 8, 2016 02:57 PM
rpm07
23
Jun 17, 2013 09:22 AM
Metdawg44
Jul 6, 2011 09:58 AM
bharris
Modular V8 (4.6L, 5.4L)
May 1, 2004 10:54 PM
BFord278
Jan 23, 2004 02:48 PM
