Recon Clearance lights
Old May 26, 2009 | 09:55 PM
njkite51's Avatar
njkite51
Hey guys, I installed the recon clearance lights on my 04 f-250 super duty. They came out great but i cant get them wired up right. I tried wiring it into my fuse panel, but it only gave me constant power. I tried all of my fuses for the lights and consoul lights. I feel like i tried every possible one. I Do not have an overhead display so i had to run the wire down to the fuse box i thought. Any ideas or thoughts i really want to get these things going. Thanks a lot
-Ryan
Old May 26, 2009 | 09:57 PM
UGA33's Avatar
UGA33
Did you splice them into the trucks lights?
Old May 26, 2009 | 10:30 PM
riggz's Avatar
riggz
you should try taping into your park light circuit.
Old May 26, 2009 | 10:32 PM
UGA33's Avatar
UGA33
Short little , you attending Smokin 09 Brian?
Old May 26, 2009 | 10:38 PM
njkite51's Avatar
njkite51
i tried the parking light fuse but its a constant hot, should i pull the switch out and tap into there? And whats a good way to find which wire it would be? Thanks for the quick responses im in and out of the garage trying to get her done
Old May 26, 2009 | 10:41 PM
riggz's Avatar
riggz
The parking lot light fuse should not be constant hot. You could try running a wire out to one of the front lights.
UGA33, probably not. that's 2 hours from me and I don't need a dyno yet. i'm waiting for the drags down in Reynolds.
Old May 26, 2009 | 10:42 PM
UGA33's Avatar
UGA33
Check this link out. It will get you squared away !
Gauge Installations at DieselManor- 2003-2007 6.0L Powerstroke
Old May 26, 2009 | 10:45 PM
njkite51's Avatar
njkite51
Yeah i dont understand why it is a constant hot, i have to take another look and try running a wire from it, thanks again for the help ill go try it and let you know what i run into
Old May 27, 2009 | 12:54 AM
GregsSD's Avatar
GregsSD
The parking light fuse is constantly hot because it is before the headlight switch. You need to tap in after the headlight switch.
Just pull the switch loose and use a 12volt test light to see which wire has power when you turn on your parking lights and tap into it there.
Old May 27, 2009 | 01:11 AM
njkite51's Avatar
njkite51
Yeah that makes perfect sense i tapped into the switch and now it works great. I thought i could take a shortcut with the fuse box, but that turned into a nightmare. Thanks for all the help guys i'll try to get some pictures up soon.
Pete0415
Jan 4, 2015 06:43 PM
Pdevore
6.7L Power Stroke Diesel
Sep 25, 2012 08:29 PM
ASizzle
2009 - 2014 F150
Jan 2, 2011 10:19 PM
Fordflanigan
Jan 4, 2009 02:09 AM
the Goat
Oct 14, 2007 06:38 PM
