My truck eats motor mounts about every 30k or so. I know the reason it does it (how I drive and work the truck). I need stronger motor mounts. I'm hoping someone out there makes a nice polyurethane unit!
I actually did a google search which is why i'm here. I'm not sure if you actually looked for Ford Truck motor mounts at that site you listed above, but they don't offer motor mounts for Ford Trucks. Only Dodge's and Chev's.
They did have some other bushings I needed... so thanks for that!
I can't find polyurethane mounts for a 300 powered F150.
I had the same problem with my 300. I took a chain about a foot long and wrapped it around the passenger side motor mount and bolted it to the frame. Never had an issue since. But you should take a look at your tranny mount too. It seemed like every time my motor mount would break it would tear my tranny mount apart as well.
