i think shorebird is right. each time you reprogram the computer, you must put in ALL keys you want to use. it erases the old numbers (except the two originals) and then add the new keys. so yes. you could have two "A" for one car, two "B" keys for the other, then program in two "C" keys that will work in both. BUT, you need to cut the lock on one car first to match the other lock.
ooooooooooops--- when you cut the lock that uses the B key to make the A key fit, how are you going to reprogram since the original key stored in the computer will no longer fit? this is getting complicated.
Many of the Ford, Lincoln, and Mercury vehicles sold since the late 90’s have come with an anti theft system known in the industry as PATS (Passive Anti-Theft System). PATS uses radio frequency identification technology to prevent the vehicle from being stolen. PATS uses a specially encoded ignition key. Each encoded ignition key contains a permanently installed electronic device called a transponder. Each transponder contains a unique electronic identification code. Each Key's code is completely different so each encoded ignition key must be programmed into the vehicle's instrument cluster module, before it can be used to start the engine.
Methinks that's what we've been trying to tell you???
Easiest way is (If the key blank is the same) is to cut one side of the key for one vehicle, and the other side for the second vehicle. My 08 SD uses the same key blank as my wife's 05 Escape. Hers is PATS, mine is not, but if it were, the same key would work in both. We had identical setup without PATS with keys double cut for Her 85 Tbird and my old Ford truck.
“Will those who are dismantling this society from within or those who seek to destroy us from without be the first to achieve their goal? It is too close to call.” - Thomas Sowell
OK but I've got a locksmith and the Ford guy who does the keys at the dealer telling me the key is getting reprogrammed so it won't work in Car A after it is programmed to work in Car B.
So, I guess I'll have to buy two more keys, cut one to fit my daughter's Focus & my wife's Escape, (provided they're the same blank), then see if I can program it for both cars. The other one will be double cut for wife's escape and my F350. The blank is the same for these.
“You cannot invade the mainland United States. There would be a rifle behind each blade of grass.” ~ Admiral Isoroku Yamamoto
According to our senior tech you can program the keys from one vehicle to work in another vehicle as well, however, you will have to rekey one vehicle to match the other
which will be expensive for the parts and labor on top of the cost of the keys and programing. Which begs the question---'Why"?. You can only drive one vehicle at a time
so you only need to carry the key for that particular vehicle. I separated all my keys years ago when I kept wearing holes in my pants pockets prematurely from the wad of keys i was carrying. Dan.
If you only have only one chip key and you buy additonal keys;
Has any F-150 owner been able to program the additional keys by
using the ONE ORIGINAL KEY TWICE. I have noted post that say
this is possible with some vehicles.
