Transmission Squeak
Old May 30, 2002 | 03:55 PM
texan_eagle_scout's Avatar
texan_eagle_scout
Transmission Squeak
I have noticed on my 2001 SCrew that onder hard(WOT) acceleration the transmission will squeak?, screech?, I'm not sure what best describes it. The engine will be warmed up, there is no noticable problems otherwise. Any ideas?
Old May 31, 2002 | 07:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Transmission Squeak
Does it just make the noise when it shifts?
Mark
Old May 31, 2002 | 12:58 PM
texan_eagle_scout
Transmission Squeak
As far as I can tell it noticeably does it from 1-2, and less so from 2-3. But then it is more noisy at that point. It might just be ever shadowed. Again this is only under "Wide Open Throttle"
Old May 31, 2002 | 01:59 PM
Mark Kovalsky
Transmission Squeak
It's the serpentine belt on the engine.
At WOT the shift is quick enough that the accesories that are driven by the belt can't slow down as fast as the engine slows, causing the belt to slip for a short time.
A new belt *MIGHT* make it go away for a little while. Other than that I don't know what to do about it.
Mark
Old May 31, 2002 | 03:41 PM
texan_eagle_scout
Transmission Squeak
A slipping belt on a truck this new? It's possible I guess. Thanks for the insight. It does sound like a slipping belt now that you mention it.
Old May 31, 2002 | 10:50 PM
Mike W's Avatar
Mike W
Transmission Squeak
Kemicalburns
Aug 8, 2016 08:30 PM
berrset
Jun 23, 2016 07:31 AM
Coachhick
Feb 19, 2016 02:44 PM
feigerou
1983 - 2012 Ranger & B-Series
Sep 4, 2008 09:26 PM
Ranger Steve
Sep 6, 2006 06:53 PM
