Anyone know why my f250 is squeaking badly?
When I first start my truck, the engine makes this horrible squeak. Can't really pinpoint where it's coming from in the engine. Once I get it past second gear while driving, the squeak completely stops. I've also noticed if I'm idling long enough after driving such as being in a drive thru for food, the squeak slightly comes back until I get going again and then it stops. Anyone ever experienced this? It's the 5.4 engine btw, forgot to include that.
Serpentine belt is a great place to start. The noise I got from mine was the idler pulley in the top middle area of the engine. It was the easiest and cheapest and happened to be the problem with mine. Now is a good time to put a new serpentine belt on as well.
You can also get a can of belt dressing and spray the fan belt. This will stop the belt from slipping and can usually help with a squeak or squeal. But if you are using dressing, there is a good chance the belt is ready to be replaced.
Teamrope
04-10-2013 10:50 PM
Dieselguy89
01-23-2008 12:05 PM
