turning up the injector pump?
Old May 25, 2009 | 10:35 PM
bigmem124's Avatar
bigmem124
has anybody heard of this? or done it? im curious because im broke right now and want more power for free. if its true how is it done? and will it hurt anything? appriciate the help ford brothers
Old May 25, 2009 | 11:15 PM
jdecker88's Avatar
jdecker88
Unless you have an IDI truck (early 94 and earlier) these trucks don't have any injection pumps. You can do some cheap exhaust mods (cutting out your muffler) and a 6637 filter until you get some funds up for a chip thats about it.
Old May 25, 2009 | 11:25 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Old May 25, 2009 | 11:37 PM
Izzy351's Avatar
Izzy351
You can also do the "10k mod" or its variants once you do the 6637 & muffler delete. It will give you a little more oomph on the cheap. Sort of like "turning up the injector pump"...
Old May 26, 2009 | 08:35 AM
brian42's Avatar
brian42
Veteran: Navy
IIRC the '10K Mod' is for high idle (inhibits carbon buildup and keeps the alternator output up during extended idle periods). You might be talking about the IDM mod...https://www.ford-trucks.com/forums/7...-pictures.html
Old May 26, 2009 | 08:55 AM
sneak's Avatar
sneak
The 10k mod is to trick your pcm into seeing lower than actual ICP numbers so it tries to raise ICP pressures.
Old May 26, 2009 | 09:10 AM
superduty4x4's Avatar
superduty4x4
Like Paul said, the 10k mod is simply putting a 10k resistor in the ICP plug to trick it into seeing low injection pressures... so it ups the pressure to compensate. Early form of a DIY chip, lots of OBS guys do it but not many SD guys that I have seen. You gain very little, but its super cheap until you can get a good chip like DP Tuner, PHP, Wildman, etc.
Old May 26, 2009 | 09:30 AM
Nick 99's Avatar
Nick 99
According to your profile, you are in the wrong Forum.
Nick
{2 Letter State/Province (use "--" for outside USA/
ar
Country
usa
Make
Ford
Model
F-250
Year
1992
Current Mileage
150,000 - 199,999
Miles per year
40,000 - 49,999}
Old May 26, 2009 | 09:44 AM
superduty4x4
Nice catch Nick.
