injector mod
Old May 25, 2009 | 07:59 PM
1997f350stroker's Avatar
1997f350stroker
injector mod
i have heard some things about being able to modify my injectors by putting a ball bearing in them and this will increase horsepower. anyone know anything about it?
Old May 25, 2009 | 08:01 PM
79_250RangerLariat's Avatar
79_250RangerLariat
You sure it's not shimming the FPR? never heard of doing anything like that w/injectors....
Old May 25, 2009 | 08:05 PM
1997f350stroker
im not sure they were talking about replacing some part and putting a ball bearing in it. i may have been injector pump but not sure. what is the FPR?
Old May 25, 2009 | 09:16 PM
kawa's Avatar
kawa
The FPR is the Fuel Pressure Regulator and a BB from a BB gun is used to increase if you have low fuel pressure. The FPR is located on the Driver's side if the fuel filter inside the large Brass Plug.
No offense meant but you might want to just monitor this forum for awhile before you start modding on your truck, The information that you glean from these members will set you on the right path and hopefully keep you out of trouble.
Rog
Old May 25, 2009 | 09:22 PM
RubberDuck's Avatar
RubberDuck
The ball bearing thing is for the regulator. Modifying an injector is a very in depth process and no where in it does it envolve a "ball bearing". Stay with us man and you will learn volumes about these trucks.
And in your defense, there are NO dumb questions here. Only the ones you don't ask. So ask away. This is not a forum that will tell you "DO A SEARCH" This forum is full of people that are chomping at the bit to help each other out. So ask away my friend, we're ready.
Old May 26, 2009 | 01:52 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
First thing WELCOME TO
Check this link about the FPR shim
042 pictures from friends & fun photos on webshots
Old May 26, 2009 | 07:51 PM
1997f350stroker
yeah i jsut put a set of stacks on and i just wanted to find a way to get more power and not spend alot of money.
Old May 26, 2009 | 08:25 PM
Epd444's Avatar
Epd444
I just did this mod today. It took me no more than 20 minutes. Theres a 3/4'' plug on the drivers side of the fuel bowl, just remove that plug and put a towel underneath before incase you drop anything. Once the plug is out there is a spring and another piece behind the spring, not sure what the exact name of it's called. The BB goes between that piece and the spring.
Sorry I can't explain it better, but it really is a simple easy thing to do.
Just check your pressure when your done, I think they say between 65 and 75 is good
Old May 27, 2009 | 06:23 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
1) Well, technically you could use a Ball Bearing in the FPR, it just has to be the size of a bb.
2) If your '97 has AB's, there actually is a Ball Bearing mod you can do to them, but I won't confuse things with that...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old May 27, 2009 | 01:35 PM
Brown Falcon's Avatar
Brown Falcon
Check your fuel pressure before doing the FPR BB mod. If it's at a good level you won't need to do it.
It is possible to do the mod and have too much pressure which can cause problems.
Old May 28, 2009 | 08:08 PM
1997f350stroker
can anyone go a little more in depth on how to **** it and what exactly i need to do.
Old May 29, 2009 | 12:02 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Did you see the link I posted in the thread # 6 ?
Old May 29, 2009 | 12:04 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Here are another pics.
Fuel Pressure Regulator Shims pictures from cars photos on webshots
Old May 29, 2009 | 12:12 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Read this, maybe is what you are looking for:
TikiWiki : Shim Your Fuel Pressure Regulator 94-97
Blind Driver
Jan 7, 2013 10:46 PM
wescon
Jan 26, 2012 06:50 PM
SAltonS
Dec 18, 2009 08:36 PM
Talyn
Oct 31, 2009 09:09 AM
caseydudem
29
Oct 19, 2007 09:16 AM
