What should Diff Temp be
Old May 25, 2009 | 12:38 PM
dt444e's Avatar
dt444e
Just a reminder, assure you have the sending unit sealed good or you could have upscale readings during wet travel.
Old May 25, 2009 | 12:46 PM
ernesteugene's Avatar
ernesteugene
Originally Posted by Kwikkordead
Yeah, that IS hot.
About 100 degrees hotter than I would have guessed.
When I went fulltime RVing in 1999 I walked the RV parks and looked under a lot of pickups towing heavy 5ers and every one of them had blistered and peeling paint on their stock diff covers!
My Mag Hytec cover had a temp sensor fitting and I used that to piggy back to the single oil temp gauge that I used for the tranny and engine oil so I took a lot of diff temp data over the years. One surprise was that my diff got "hotter" going down a long mountain grade using my US Gear exhaust brake than it did towing up the grade!!! I think the "ring and pinion" gears generate a lot more "friction heat" when they're used to provide "reverse TQ"!
Old May 25, 2009 | 02:06 PM
Ziggy.'s Avatar
Ziggy.
Thats very interesting, I never thought of that. I wonder if it would be because the teeth would be running on the opposite side compared to "forward TQ". Just a thought, but interesting non the less.
Old May 25, 2009 | 03:16 PM
Izzy351's Avatar
Izzy351
So what kind of temps did you see, Gene? I'm curious, but not enough to put in another sender...
Old May 26, 2009 | 03:57 PM
ernesteugene
You can use a "paste on" strip which turns different colors as a function of the maximum temperature it sees and use that as a "one time" measurement of diff temp.
The maximum I saw was 250 F but I had one of these... Ford #12-10.25 & 10.5 [Ford #12-10.25 & 10.5] - $260.00 : Mag-Hytec ...which holds 6 quarts and has deep cooling fins on the cover.
Towing flat at 65 mph with an AAT=80 F I saw about 180 F.
RAGrove
2015 - 2020 F150
Mar 17, 2015 08:25 AM
samiam417
2004 - 2008 F150
Jun 15, 2014 04:47 PM
Ken_C
Apr 11, 2014 12:12 PM
Greywolf
General Automotive Discussion
Jun 7, 2013 10:20 PM
sparkkky
2004 - 2008 F150
Aug 21, 2011 03:02 PM
