Running Board braces / supports
Old May 24, 2009 | 08:48 PM
Wrecker's Avatar
Wrecker
I have a 96 F150 Eddie Bauer 4x4. The supports for the fiberglass running board on the pass side rusted out. Upstate new york winters take there toll.... I really would like to keep the original running boards. Can anyone tell me where I can purchase the original style supports? Cant find them around here. Any help would be greatly appreciated!
Thanks
Paul
Old May 26, 2009 | 06:27 AM
SuperFord's Avatar
SuperFord
I have the same problem. I am thinking about welding new support bars in, but I have no idea how involved it will be yet.
Old May 26, 2009 | 06:29 AM
dustybumpers's Avatar
dustybumpers
prob going to be junk yard item, if you can't find there, you'll have to take off what's left, and fab new ones to match the old ones. should'nt be to bad a job, they're mostly flat bar, and angles
Old May 26, 2009 | 07:29 AM
Diesel_Brad's Avatar
Diesel_Brad
keep an eye on craigs list, ebay or build your own
Old May 27, 2009 | 04:01 PM
SuperFord's Avatar
SuperFord
Well, I got mine off, in 3 pieces. The fiberglass is fine, but I will have to do some repairs to the support. I am thinking bending new metal and welding it back together.
Old Jun 2, 2009 | 11:18 AM
1994XL4X4's Avatar
1994XL4X4
cab step supports
What I did was cut the existing supports off to solid metal. Then I bent some conduit to slip inside the cut off ends and painted black and they have held up for over 2 years so far. To bolt the cab-steps to the brackets I removed the black step plate, drilled down through the metal support on the bottom of the cap-step; through the "new" support then re-installed the black step plate.
Old Jun 2, 2009 | 08:09 PM
94XLTFLAREI6's Avatar
94XLTFLAREI6
same problem here.....I need to fix mine too....
perks56
Feb 7, 2014 11:22 AM
aussiecowboy
Apr 25, 2013 12:16 AM
95F150SuperCab
May 12, 2012 07:49 PM
detroitfd
1997 - 2003 F150
Dec 5, 2010 06:24 PM
Mr. Finch
Mar 9, 2010 06:18 PM
