factory running boards?
Old Mar 7, 2010 | 04:32 PM
Mr. Finch's Avatar
Mr. Finch
I have a 96 150 standard cab. It has the factory runningboards and the supports are rusting, just had the pass side break.
My question is does anybody know where to get the supports for these trucks, dealer no longer stocks them, the parts stores say they can't get them, and all the boneyard ones are rusted the same (northern illinois, big surprise)
Any suggestions would be nice.
Old Mar 7, 2010 | 04:35 PM
zxwut?'s Avatar
zxwut?
Use an aftermarket one? I have the Carr Super Hoop and I am very pleased with them.
Old Mar 7, 2010 | 05:15 PM
Mr. Finch's Avatar
Mr. Finch
I have thought about that, but I kinda like the way the OE ones look. If I can't find the brackets I am looking for I will either custom make the brackets, or install aftermarket boards.
Any suggestions on aftermarket running boards is also appreciated.
Old Mar 7, 2010 | 05:33 PM
NavyMIDN08's Avatar
NavyMIDN08
check with your local wrecking yard and see if they can have rust free ones shipped in from out of the area. most yards are connected in a network where they can check each other's stock. beware this could get costly. best bet may be to fabricate your own.
Old Mar 7, 2010 | 05:44 PM
cjben's Avatar
cjben
if you can't find them in a junk yard,you will have to get them fabbed up,nobody makes them. This has been asked several times,nobody has found a supplier yet.
Old Mar 7, 2010 | 07:24 PM
TexasGuy001's Avatar
TexasGuy001
I want a pair of the OEM steps like the EB and flareside have. What I would do is just make your own brackets and reinforce them.
Old Mar 7, 2010 | 07:31 PM
Diesel_Brad's Avatar
Diesel_Brad
LUND made the factory steps for FORD and they made their own. You may be able to locate a Obsolite set in a warehouse w the LUND name on them. Either that or make new brackets out of real metal instead if sheet metal
Old Mar 7, 2010 | 09:50 PM
TexasGuy001
Do you know for a fact that the OEM ones are made by LUND? The LUND ones aren't exactly the same as the factory Ford ones.
Old Mar 7, 2010 | 11:03 PM
mstngmikegt's Avatar
mstngmikegt
I can't say for sure, but I always thought the factory boards were made by Lund. The Lund "Street Boards" or whatever they were called look the same to me. Was told awhile back that they were going obsolete and their site does not show them as available, but maybe with a phone call they have some backstock of the brackets, etc available?
Old Mar 8, 2010 | 03:46 AM
Diesel_Brad
98.9% sure
Old Mar 8, 2010 | 09:39 AM
dwrestle's Avatar
dwrestle
I think you would be better off going with an aftermarket step or tube that bolts to the frame because that would be much stronger. I broke my factory running boards off of my truck by putting all my weight on them last week so I took them off the rest of the way. In fact I just finished taking off the matching mud flaps in the front last night. The passenger side is what initially broke, and it broke off the mount from behind the cab. The truck looks much better now thats for sure.
Old Mar 9, 2010 | 06:18 PM
ptboi94's Avatar
ptboi94
go to a junkyard. most of them are connected and you can probably find a whole runningboard and brackets in good condition
fordguy2100
19
Jan 23, 2017 09:06 AM
Catchad
18
Jun 20, 2016 09:12 PM
Mike7152
Mar 15, 2016 09:18 PM
52caddy
Escape & Escape Hybrid
Feb 5, 2016 11:22 AM
richlars
Jul 16, 2014 05:13 PM
