ts performance chip
Old May 23, 2009 | 09:01 PM
bostergard's Avatar
bostergard
ts performance chip
anyone know if this chip from a 2002 will fit a 2000? They have two different part #'s according to their website
Old May 23, 2009 | 09:17 PM
Ziggy.'s Avatar
Ziggy.
Welcome to FTE. Unless they had the same pcm code they wont work I do believe, hince the different part numbers. You might want to look into a DP tuner, or a custom tuned TS chip, there is a big difference in between what tunes come on the TS chip compared to custom tunes.
Old May 23, 2009 | 09:23 PM
bostergard's Avatar
bostergard
TS Performance chip
Thanks Cory, I found the chip for 250 used and was going to use it until I got the other 150 to have Tony Wildman reburn it for me. I will call TS performance on Tuesday and find out for sure.
Old May 23, 2009 | 09:27 PM
Izzy351's Avatar
Izzy351
2002 is definitely different. 2002 & 2003 are VDH-* PCMs, the 2000 is probably a PMT-*. You will LOVE Tony's tunes!! Don't even try it in your 2000...
Old May 23, 2009 | 09:32 PM
bostergard's Avatar
bostergard
Thanks a bunch Cory. Will just get a new one from Tony
Old May 23, 2009 | 10:27 PM
jdecker88's Avatar
jdecker88
A TS chip is a nice one to have because you can get several good tuners to tune it for a fraction of the cost of a new chip it doesn't matter if it is a 94-03 they all work when they are reburned.
