Volant Harmonics
Old May 23, 2009 | 07:34 PM
Fordication's Avatar
Fordication
Volant Harmonics
Hey guys. I went ahead and bought the Volant intake that you told me about and installed it. Honestly I do not see why its better than the other ones and the sound is ok but when you step on the gas I am getting a harmonic distortion that is not in the least bit attractive. It starts around `1900 RPM up to about 2200 RPM and then it goes to the roar you guys describe. It sounds and feels like vibrations thru the truck. Anyone else have this and what did you do to fix it.
Old May 23, 2009 | 08:02 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
never had any harmonics with mine...and I spent alot of time in the 1500-2500 rpm range
is your box bolted down securely?
I've heard of guys strapping matting to the inlet tube on the Volant and other Intakes.
Old May 23, 2009 | 08:10 PM
bridge's Avatar
bridge
Sick 'n Tired
Yes, I get that sound too. I just assumed it was because I didn't bolt down the case down well enough. Try a sheet of foam rubber, then bolt it down.
Old May 23, 2009 | 10:22 PM
Fordication
Under the box? Thats a pain but I will try it.
Old May 23, 2009 | 10:23 PM
Fordication
Oh, and I bolted it down real well. So tight it dented the plastic.
Old May 24, 2009 | 09:42 PM
Fordication
Well tomorrow I am going to use one of my spare thick rubber mousepads under the filter box and see if that makes a difference. Anyone else have the plastic pipe actually touching the firewall above the throttle body?
Old May 24, 2009 | 10:07 PM
bridge's Avatar
bridge
Sick 'n Tired
Yup...got that too. Volant had a number of units ship with a badly molded pipe that resulted in an extremely tight fit. Some on here had volant replace the pipe free of charge. I muscled mine on and left well enough alone. If you think that's the issue you should be able to cut off a quarter of an inch or so to get it off the firewall. There was a post on here a couple of years ago about this issue...
Edit: Here it is https://www.ford-trucks.com/forums/7...ml#post5778071
Old May 24, 2009 | 11:06 PM
ford-this's Avatar
ford-this
i get that noise too i have mine bolted down and my plastic pipe does touch my fire wall too...i think it sounds sweet the sound it makes i always keep gasing on it to make that sound kills the mpg but oh well your only young once!!
Old May 25, 2009 | 01:19 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
mine never touched my firewall
that could be where the noise is getting transmitted...I never experienced it, so it sounds likely
btw, did you use the rubber isolators under the intake box?
Old May 25, 2009 | 04:38 PM
Fordication
What rubber isolators.
Old May 25, 2009 | 05:05 PM
bridge's Avatar
bridge
Sick 'n Tired
Yeah...what rubber isolators? I looked over the install instruction again, no isolators mentioned.
Old May 25, 2009 | 09:08 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
EDIT:
whoops, sorry. I am getting my Volant and the Roush CAI confused.
The Roush has 3 big rubber isolators, and the Volant was just hard bolted
sorry for the confusion
Old May 25, 2009 | 10:11 PM
VFR_Man's Avatar
VFR_Man
Mine did the exact same thing. The tube would have touched the firewall if I hadn't trimmed ~1/4" off of the rubber coupling sleeve to let the tube sit lower.
I couldn't figure out how to get rid of that noise, so that's why mine is for sale in the classifieds.
Old May 25, 2009 | 10:14 PM
pb34's Avatar
pb34
Interesting, I don't have that noise with mine nor does it touch the firewall.
Old May 26, 2009 | 12:00 AM
Fordication
Mine does it right before it gets about 2300 RPM. Above that its a good sound but its a harmonics like something is vibrating against the firewall or the metal. I have yet to try to fix it but as soon as I can I will. I do not think rubber grommets will work so I am going to put a hard rubber pad under the box then another one on the firewall next to the pipe. If that does not do it I will try something else.
