AC Problems
Old May 23, 2009 | 05:40 PM
bigtimebubba's Avatar
bigtimebubba
AC Problems
So I tried to search but couldn't find it.
The problemm with my AC. I will turn it on to Max AC and it will work for about 5-15mins and then it will just blow luke warm or hot damp air out after that.
If I turn it off and then let it "rest" for a little while and turn it back on it will do the same thing again. I have noticed on the highway that if I have the RPM's around 2k that it will blow cold air for longer and can last for up to 25-30mins but it seems like it will eventually blow warm again. I had the system completely recharged at the end of last summer but it did the same thing then also.
I remember reading about adjusting or taking out shims in the AC compressor, but can't remember if this was to fix I need to do.
Any advice needed, when friends ride with me and my wife I always feel bad if the drive is longer than 30mins.
Help me get my AC working correctly again
Thanks
Bubba
Old May 23, 2009 | 06:34 PM
SpringerPop's Avatar
SpringerPop
https://www.ford-trucks.com/forums/5...ml#post4464164
(I need to bookmark that page, as I have to hunt it down every time.....)
Pop
Old May 23, 2009 | 06:45 PM
lowbed dud's Avatar
lowbed dud
try and run it on regular ac, some times they will frezze up in max ac,letting it set will
let it thouout, just my 2c, happens in my simi
al
Old May 23, 2009 | 07:08 PM
SpringerPop
He's got the classic symptoms that come along with the air gap having worn too wide for the electromagnet in the clutch to dependably engage.
Pop
Old May 23, 2009 | 07:17 PM
bigtimebubba
I'm a total noob.
Where is the AC clutch found.
Thank you for posting up the link for the thread
Old May 23, 2009 | 08:11 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by bigtimebubba
I'm a total noob.
On the front of the compressor. From the front of truck just to the right of the engine oil dipstick.
Old May 23, 2009 | 09:52 PM
bigtimebubba
I thought that was the HPOP. Is it high up on the engine?
Sorry for the noob questions. I know close to nothing on Powerstrokes
Old May 23, 2009 | 10:19 PM
PaysonPSD's Avatar
PaysonPSD
On top of engine. Serpentine belt goes over top of compressor pulley. That pulley free wheels until the AC clutch engages locking the pulley and spinning the compressor to build pressure. It is right behind the passenger side of the coolant overflow reservoir (commonly referred to as the degas bottle).
The HPOP is under the fuel bowl.
I was once a newbie myself. Absolutely no apologies necessary. Asking questions is how you will learn, and we at FTE are willing to teach.
Old May 23, 2009 | 10:25 PM
bigtimebubba
Okay.
Thanks Payson.
It's the same part, I just thought it was the HPOP.
I will get to it on monday using the thread posted above to hopefully fix the problem.
Thanks to everyone for the help, I appreciate it
