Bellhousing to engine spacer missing
Old May 22, 2009 | 05:01 PM
lizards's Avatar
lizards
Question Bellhousing to engine spacer missing
In my haste and bad memory I left out the spacer that goes between the I6 300 engine and bellhousing. I have the whole thing back in the truck with a T18 bolted up behind it.
I am now contemplating pulling it all out and apart to put the spacer in and wondering if the spacer is really necessary.
Can I get along with out putting the spacer in?
Old May 22, 2009 | 09:20 PM
drof46's Avatar
drof46
I bought a truck with a missing c4 spacer. Not sure about your setup, but the flywheel was exposed and subject to all the dirt, rocks, and water from driving. I now have everything buttoned up and safe from debris.
Old May 22, 2009 | 09:58 PM
flipklos's Avatar
flipklos
Helps set the spacing for the starter. You kinda need it. Plus do you realy want to install a new ring gear?
Old May 23, 2009 | 04:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The spacer the OP is refering to is not a flywheel or flexplate inspection cover aka dust cover.
It's a flat plate that fits between the engine and trans.
It has to be there.
The plate used with a manual trans is not the same for an automatic.
Old May 23, 2009 | 07:54 AM
drof46's Avatar
drof46
Mental note made.
Old May 23, 2009 | 11:14 AM
Bill W's Avatar
Bill W
Patagonia, AZ. What a beautiful place! your gonna need to install the plate,
not only does it affect the starter but also the pilot bearing as the input shaft sets too deep.
b1gbl0ck
Feb 15, 2016 08:08 PM
strickland
2015 - 2020 F150
Aug 6, 2015 10:12 AM
manning-2
Feb 20, 2015 01:17 AM
hillcountryflt
Jan 23, 2015 02:51 PM
1982_f150
Feb 16, 2014 06:21 PM
