Sponsored by: Kumho
Wheel Spacers
Old Feb 14, 2016 | 09:11 AM
b1gbl0ck's Avatar
b1gbl0ck
Wheel Spacers
Hey guys I just recently purchased 4 wheel spacers, I've done my research and bought quality ones. The main reason I bought 1.5" spacers is because my front tires rub my leafs at full turn. I installed my front spacers and obviously had to cut off about a quarter of an inch, installed rims/tires and everything was good once torqued. I went to the rear studs, dry fitted my spacers on and discovered that my OEM studs stick out almost an inch passed the spacers which means I'd have to cut that much off. If I plan to leave my spacers on, do you think it would be a problem cutting that much? I don't do any towing and rarely have a heavy load if it matters. I do not want to replace studs. Thanks, Doug
Old Feb 14, 2016 | 10:47 PM
RainDesert's Avatar
RainDesert
I don't see any problem. I guess the studs are just longer than the fronts. Or just don't run the rear spacers until you are ready to cut them. The problem would be if you ever didn't want them.
Old Feb 15, 2016 | 08:08 PM
b1gbl0ck's Avatar
b1gbl0ck
Awesome that's what I was thinking, thanks for the feedback.
dylansf23
Jun 26, 2014 08:20 PM
yukgoon
Aug 3, 2010 01:13 AM
weekendwarriorfsw32
Apr 27, 2010 04:08 PM
stroken
Dec 15, 2009 10:31 PM
96_fordF150
Apr 17, 2008 01:04 PM
