Water Pump help!!
Old May 22, 2009 | 02:02 AM
hayden01's Avatar
hayden01
Water Pump help!!
I have a '76 302 that the water pump went out on and I was wondering if the water pump from a '83-'84ish 351W will fit.
I have the 351W in my gerage waiting to be built and I need a water pump now but am a lil short on money for a reman or new from the local parts house. Just wondering this little question to save myself some money and hair pulling.
Thank you guys in advance!!
Old May 22, 2009 | 06:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It depends on which waterpump your 1976 F100 302 has, because there were two different pumps used in 1976 on 302 F100/150's.
DOOZ8501C .. Waterpump
Fits: 1969/75 F100/150 302 / 1976 F100/150 302 before serial number B75,001.
D6ZZ8501B .. Waterpump
Fits: 1976 F100/150 after serial number B75,001 / 1977/86 302.
Fits: 1980/87 F150/350 & Bronco 351W.
The serial number is the last 6 digits of the VIN.
Old May 22, 2009 | 12:14 PM
hayden01's Avatar
hayden01
Well accualy my 302 is out of a '76 Ford Granada. Did the car 302's still have two diferent water pumps?
Old May 22, 2009 | 12:22 PM
NumberDummy
Well actually my 302 is out of a '76 Ford Granada.
Did the car 302's still have two different water pumps?
Not when it comes to 302/351W Ford Granada's and Mercury Monarch's.
Fits: 1975/80 Granada/Monarch 302 & 351W.
The next question is...
What's the "83ish, 84" 351W from? Passenger car or F150/350, Bronco or Econoline?
I assumed it was from a F150/350. I SHOULD know better than to assume ANYTHING on FTE!
If it's also from a car, it may not be the same as the D6ZZ8501B waterpump, because...
1979 and later LTD/Crown Vic's, Mercury Grand Marquis and 1980 and later Lincoln Town Cars used a different waterpump for 302/351W engines.
Old May 22, 2009 | 12:25 PM
hayden01's Avatar
hayden01
Even if the 302 is Granada and the 351W is Bronco?...Sad
Old May 25, 2009 | 02:51 PM
INKAHOOTZ's Avatar
INKAHOOTZ
one quick question guys .... how can I tell a reverse water pump from a older v belt pump ? I was digging through my used pump box (about 9 or 10 pumps and 1/2 is reverse ) and could not quickly identify the differnce . thanks rg
money pit 69
Nov 6, 2014 02:16 AM
64deville
Dec 15, 2011 07:36 PM
hackodom
Jul 3, 2011 08:11 AM
mercman65
Jul 18, 2009 09:46 PM
fishin machine
Jun 22, 2004 09:05 PM
