351W rebuild
Old Nov 2, 2014 | 08:12 PM
money pit 69's Avatar
money pit 69
351W rebuild
Hello just wondering if anyone might have a input. I bought a low mileage used 351w to replace the one in my 1987 F-250 4x4. Before I put it in I'm replacing such as oil pump, water pump, gaskets, timing set and normal little parts. My question is should I replace the harmonic balancer and is there anything else you can think of.
Also did the factory use cork gaskets or has this been opened before. It's awful clean inside.
THX David
Old Nov 3, 2014 | 06:52 PM
CharlieLed's Avatar
CharlieLed
If the rubber in the harmonic balancer is rotted then it's time for a new one...otherwise you should be fine.
Old Nov 3, 2014 | 07:40 PM
money pit 69
THX for the info. I'm removing it tomorrow I'll look it over good.
Old Nov 4, 2014 | 09:30 AM
Conanski's Avatar
Conanski
Yeah check the alignment of the balancer timing marks when #1 piston is TDC on the compression stroke, if they don't line up then the rubber has broken lose and the balancer is junk.
Old Nov 4, 2014 | 10:32 AM
Island Time's Avatar
Island Time
Paul, I feel like I should know the answer to this, but it is completely escaping me. Can you tell the compression stroke on #1 without pulling the valve cover? (I too need to verify balancer, plus realign distributor because I forgot to mark rotor position when I pulled it.)
Old Nov 4, 2014 | 02:56 PM
Conanski's Avatar
Conanski
Pull the spark plug, put a thumb over the hole and have somebody rotate the crank by hand with a breaker bar until you feel air being pushed out. Slowly continue doing this until it's no longer pushing air and then use a piece of stiff wire(coat hanger) in the plug hole to feel the piston reach TDC.
Old Nov 4, 2014 | 06:24 PM
Island Time
Yup. That's what I was trying to remember, the thumb over the hole. I wish my mind wasn't so full of mush lately. Thanks much.
Old Nov 6, 2014 | 02:16 AM
BuzzLOL's Avatar
BuzzLOL
. To accurately find TDC you'll need a piston stop tool (~$5) that screws into #1 sparkplug hole...
mawagian
Oct 18, 2015 04:41 PM
Kai
Feb 18, 2003 12:30 AM
51truck
Jul 22, 2002 04:47 PM
StockMan
Jan 6, 2002 04:20 PM
