water pump leaking
Old May 21, 2009 | 10:26 PM
Greenmachine_76's Avatar
Greenmachine_76
water pump leaking
ive got a 76 f150 witha 390. my question is when i part on an incline anti freeze leaks out of a hole on the bottom of my water pump. i also can only fill the radiator so much and it starts leaking. does this mean the water pump is bad? thanks for the help
Old May 21, 2009 | 10:42 PM
Kruse's Avatar
Kruse
Yes. Replace it.
Old May 21, 2009 | 10:45 PM
Greenmachine_76
what does that mean exactly if it is leaking from there
Old May 21, 2009 | 11:06 PM
73CaliF100's Avatar
73CaliF100
That is called the weep hole. If it leaks, that means the pump is going bad. There is a seal or bearing inside that wears out and water will pass by and out the weep hole.
Old May 22, 2009 | 01:40 AM
Alvin in AZ's Avatar
Alvin in AZ
The bearings were so loose on my FE's water pump the fan looked like it was
going to fall off. It happened pretty quick, once the bearings "had enough"
they went bad quick. But it didn't leak a drop. LOL :)
My experience with other brands' designs have been just the opposite, the
bearings seemed fine but the seal leaked anyway. Anybody else, or just me?
Alvin in AZ
Old May 22, 2009 | 06:56 AM
Kruse's Avatar
Kruse
It means you are leaking coolant and your water pump is bad. It also means that if you don't replace it, worse things could happen, like overheating your engine and ruining it or even the fan moving forward and going through your radiator.
Old May 22, 2009 | 08:49 AM
73CaliF100's Avatar
73CaliF100
Alvin in AZ
Same thing happed to me...I guess the "weep hole" doesn't work so good on the FE pumps.
Old May 22, 2009 | 01:01 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
What happens is two things. The water seal itself can seal well, while the bearings go bad. Or the seal itself goes bad first from sitting, and usually not the seal, but the surface of the cast-iron impeller rots.
Old May 25, 2009 | 07:32 PM
orich's Avatar
orich
One more little thing with the stock system is unless you've added a recovery tank you can't fill the rad to the top or it will be pushed out the overflow tube. Or you must only fill it to about 1.1/2"-2" to the top with coolant...Most auto stores have the little plastic tanks with a sealed type cap and hose. for about 10 bucks...my 2cents
orich
Old May 26, 2009 | 11:44 AM
krewat's Avatar
krewat
orich
Good call... the top of the radiator IS the expansion tank. I had a radiator support from a junkyard donor truck that still had the stock sticker on it. I believe it said something to the effect of filling the radiator just so that the cores are covered with coolant.
arsleuthster
Oct 28, 2025 12:54 PM
arkredneck
Jan 13, 2014 10:19 PM
gbeach
13
Jun 6, 2007 07:12 AM
Scott's 88 F150
Mar 8, 2004 07:19 PM
beckandyork
May 20, 2002 04:07 PM
