Turned the fuel down
Old May 20, 2009 | 08:39 PM
harleyjohn45's Avatar
harleyjohn45
I posted recently about high egt's. Lots of thoughtful answers and they were appreciated.
I turned my fuel down 1.5 flats or in my estimation 90 degrees. The fuel had been turned up 110 degrees, so i think I'm still advanced 20 degrees or about 1/3 flat. George D told me how to increase the boost, so I shortened the waste gate rod by a total of 6 turns or threads. With 28 tpi, then I've decreased the wastegate rod almost 1/4 inch. At low RPM I still get a small puff of black smoke, but at speed I see nothing.
I have not tested the truck loaded, but running empty, I can pull these hills at 2600-2800 rpm and keep the egt's at 1000. Most of the hills I have to drop to 3rd.
I actually think I could have gone back to the stock fuel setting, because I still have good power. My boost seems to go to 5 psi fairly quickly. I saw 7 lbs of boost one time when I got on it hard, so I'm fairly close to my desired setting of 8 lbs.
Now I hope to get the speedometer working again next week.
thanks everyone.
Old May 20, 2009 | 10:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Sounds like you are getting closer to where you need to be.
Old May 20, 2009 | 10:43 PM
harleyjohn45
That old truck might even make it back to florida in the fall.
whalebus2112
Dec 29, 2012 09:32 PM
boots6868
17
Jun 20, 2012 09:23 PM
94iditrbo
Mar 26, 2012 03:47 PM
harleyjohn45
13
Jul 1, 2009 10:47 PM
harleyjohn45
80
May 5, 2009 08:24 PM
