Towing
Old May 19, 2009 | 09:01 PM
rjdpowerstroke's Avatar
rjdpowerstroke
Question Towing
ok i got a 2006 f350 diesle super cab short bed . thinking towing a gooseneck trailer like a 24 or 25 ft one and putting my hydromobile scaffolding on it, it is 24ft long 7 ft wide and weights 7200lbs , my question is can my truck tow it and if so can i tow it legally. thanks for any info or help
Old May 19, 2009 | 09:07 PM
flamebuster's Avatar
flamebuster
you can tow that with out any problems.. Your truck won't even know it is there..
Old May 19, 2009 | 10:05 PM
Sader's Avatar
Sader
Legally, I would think so. Weight,........what else are you gonna put on that trailer? Is that 7200lbs plus the trailer? Even if it is, Just remember to look behind you every once in a while. You will forget it's back there.
Old May 19, 2009 | 11:27 PM
Desertelkhunter's Avatar
Desertelkhunter
that is like towing air I tow a 10k trailer at 80 and smile as I pass folks
Old May 20, 2009 | 06:56 AM
tex25025's Avatar
tex25025
The gooseneck you have can probably handle 12.5k and if I'm reading your post right your cargo is 7,200. Even if you max out your trailer, your truck can still haul it and unless your truck is heavy enough(sticker weight) to bring your total to or over 26,001(use trailer sticker weight as well) you should be able to legally tow it. Exemptions to that depend on the state your in.
Old May 20, 2009 | 05:42 PM
rjdpowerstroke
thanks guys and yes it is 7200lbs plus trailer and ill be moving the stuff in illinois to answer other question
tperk100
All Things Towing
Mar 18, 2012 01:40 PM
2012 SD Snowbuster
All Things Towing
May 31, 2008 12:54 PM
billwane
All Things Towing
16
Dec 7, 2007 07:38 AM
medhvac
Missouri Chapter
28
Mar 31, 2007 09:11 PM
medhvac
All Things Towing
Mar 20, 2007 09:22 PM
