cylinder contribution test, here's the codes
Old May 19, 2009 | 06:12 PM
glasseater's Avatar
glasseater
p0263
p0266
p0269
anyone have any idea what these mean? i'm hoping one or more cylinders aren't low
Old May 19, 2009 | 08:46 PM
BlueMule's Avatar
BlueMule
The codes say that 1, 2 and 3 were not contributing during the test. What scanner were you using? How many times did you run the CCT? I've ran it back to back a number of times with AE and had it fail on 2, 3 or 4 different cylinders each time and even failed on all 8 once. Did you notice what your EOT was? There is a minimum required to run the test but I've found that when temps are near the minimum it will fail cylinders but if it's closer to 200* they all pass.
Old May 19, 2009 | 09:59 PM
oldbird1965's Avatar
oldbird1965
sound like the test is unreliable but what do I know, I've never done one.
Old May 20, 2009 | 07:57 AM
glasseater's Avatar
glasseater
EOT was around 165*, i'm guessing that's why it got cofused!! and yes i was using my scangauge
definitely sounds like the scangauge is not very reliable with this test
Old May 21, 2009 | 01:37 PM
c00nhunterjoe's Avatar
c00nhunterjoe
if it was below 170 the test is not supposed to run
Old May 21, 2009 | 02:41 PM
glasseater's Avatar
glasseater
it might've been slightly over 170? i'm not sure on the actual temp, i'll try it again within the next couple days and make sure its 180+
Old May 22, 2009 | 05:41 AM
tjbeggs's Avatar
tjbeggs
Its not the Scanguage its the test in general. No matter what scan tool you use it could have that issue.
Old May 22, 2009 | 07:38 AM
glasseater's Avatar
glasseater
thanks tim, in that case i'm guessing its just cause it wasn't warmed up enough?
Old May 22, 2009 | 12:25 PM
c00nhunterjoe
run the crap out of it then pull over and run the test.
Old May 22, 2009 | 12:59 PM
glasseater's Avatar
glasseater
i'll try that coon and see what happens
