Thermostat difference
Old May 19, 2009 | 02:38 AM
Dusto5's Avatar
Dusto5
My engine is coming together nicely, but I'm running into a bit of a snag. The normal parts-house thermostat for an FE, is too small to fit my
C6AZ-H manifold. It slides right thru the hole for the thermostat, and the thermostat flange just barely fits the aluminum water neck. Anyone know what the right thermostat is?
Old May 19, 2009 | 04:55 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Ask for a Mopar 318-440 stat. Napa # 191. That's a 180* stat. Also Stant # 13078 fits. They can take it from there in the right temp you need.
Old May 19, 2009 | 05:37 AM
jowilker's Avatar
jowilker
Not to disagree, there are two t-stat sizes, Bill should know which engines they fit. Your parts house should have both.
John
Old May 19, 2009 | 06:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Y Block & FE 2 1/2" O.D. Thermostats
1958 thru 12/1/1966: FE t/stats used in cars are 2 1/2" O.D.
After 12/1/1966, FE car t/stats are 2 1/8" O.D.
1965/67 352's in F100/350's are all 2 1/2" O.D.
1968/76, they're 2 1/8" O.D.
All 239/256/272/292/312 Y block t/stats are also 2 1/2" O.D. These same 2 1/2" t/stats are the same as FE's used.
Good indie auto parts stores and NAPA may stock these 2 1/2" t/stats. Blotto-zone, Kragen, Checker and etc. may not.
If y'all cannot find any...
A8AZ8575F .. 190 Degree 2 1/2" O.D. Thermostat (Motorcraft RT19) / Obsolete
GREEN SALES CO. in Cincinnati OH has 21 = 800-543-4959.
PARTS INTERNATIONAL in Farmers Branch TX has 12 = 888-727-0418.
KINSEL L/M in Beaumont TX has 8 = 800-816-2894.
BOB ALLEN FORD in Overland Park KS has 5 = 800-676-0675.
A8AZ8575E .. 180 Degree 2 1/2" O.D. Thermostat (Motorcraft RT18) / Obsolete
GREEN SALES CO. has 47.
MILLER OBSOLETE PARTS in Binghamton NY has 8 = 800-546-7278.
BOB ALLEN FORD has 8.
A8AZ8575D .. 160 Degree 2 1/2" O.D. Thermostat (Motorcraft RT16) / Obsolete
GREEN SALES CO has 44.
MILLER OBSOLETE PARTS has 36.
ANTIQUE AUTO SUPPLY in Arlington TX has 9 = 817-275-2381.
WESLEY OBSOLETE PARTS in Liberty KY has 9 = 606-787-5293.
Most good autoparts stores can cross Motorcraft part numbers over to the brands they sell.
Old May 19, 2009 | 01:11 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
I should have mentioned the ones I posted about are the larger 2.5" stats. Most stores only list the smaller 2.125" stat for the FE. Somewhere along the line the larger one was dropped as an option it seems.
Old May 19, 2009 | 03:37 PM
Dusto5's Avatar
Dusto5
Thanks for the info guys. One Napa here where I live, and another in Havasu both only showed the smaller. You fellas are a weath of info.
Old May 19, 2009 | 04:59 PM
jowilker's Avatar
jowilker
Go back and get them to look a little harder, I bet they will find it for you.
John
Old May 20, 2009 | 09:52 AM
desoto dave's Avatar
desoto dave
i ran into the same situation on my build.the intake usedthe larger thermastat,and the original thermastat housing that came from my 360 was for the smaller one,so i took it the housing to the machine shop and they made it fit for the larger one.worked great.
Old May 20, 2009 | 01:33 PM
Dusto5's Avatar
Dusto5
I went back to Napa, and found one. The application he found in the book was for 50's and 60's Ford truck inline sixes and V-8's (Y-blocks). The part number on the box is 291.
Old May 20, 2009 | 03:08 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
The 291 is a 195* stat 2.49" dia and should fit fine. It's also one of the same numbers listed for a 1970 Dodge 318 engine. Depending on the temp range they have 160*-195*. If you look up say a 64 Ford Galaxie w/390 it shows the same numbers for the same stats. It's all pretty generic. 66-67 was the change over timeframe from the big to small stat housings. So your 66 part number was in the changeover and they are not that specific at NAPA or the chainstores to know it. NAPA online shows the same part numbers for both Ford and Mopar.
Bill thank you for posting the Motorcraft thermostat numbers! I had no idea there was still some out there kicking around. I want to pickup a couple of them. Hope you've been well. I still owe you a phone call.
Old May 22, 2009 | 09:58 AM
fuji0030's Avatar
fuji0030
The 291 is a 195* carbon 2.49" dia and should fit fine. It's aswell one of the aforementioned numbers listed for a 1970 Dodge 318 engine. Depending on the acting ambit they accept 160*-195*. If you attending up say a 64 Ford Galaxie w/390 it shows the aforementioned numbers for the aforementioned stats. It's all appealing generic. 66-67 was the change over timeframe from the big to baby carbon housings. So your 66 allotment amount was in the about-face and they are not that specific at NAPA or the chainstores to apperceive it. NAPA online shows the aforementioned allotment numbers for both Ford and Mopar.
_________________
Thermostat
Old May 25, 2009 | 08:12 PM
orich's Avatar
orich
Saw an 3/8" adapter plate on ebay a few times to convert it to the smaller size made from aluminum looked like a pretty good setup, even came with longer bolts, I think 20 or 25 bucks..
orich
Old Jun 1, 2009 | 01:14 AM
Dusto5's Avatar
Dusto5
Took the 291 back and exchanged it for a 191 (180 degree).
YooperUno
Oct 20, 2016 01:12 PM
Danner717
Jan 13, 2016 01:52 AM
Nigel
Aug 28, 2007 10:23 PM
crecity678
20
Feb 23, 2005 05:00 PM
68_PoolvilleTX
Jan 24, 2005 05:52 PM
