1978 - 1996 Big Bronco
RABS Module loaction?
Old Sep 13, 2016 | 02:01 PM
rlvbronco's Avatar
rlvbronco
Question RABS Module loaction?
Ok so I'm thinking the RABS module is at fault for my Broncos speedo to not work, and the hard shifting. I know the RABS Module is wired in with the PSOM (Programmable speedometer / odemeter module) and the PCM ; I don't think it's the PCM to blame Because my ABS dummy light is lit constanly, and I am getting code 452. If anyone can tell me where my RABS Module is located on my 1995 ford bronco 351w or even send me a pic that would be amazing!
Old Sep 14, 2016 | 10:13 AM
jimbo285's Avatar
jimbo285
The Sensor is in the rear diff. It's the speedometer drive also. The module is on left frame rail forward and beneath the master cylinder area. If you look at the steering gearbox from above it, the module will probably be in the way.
Old Sep 14, 2016 | 05:12 PM
rla2005's Avatar
rla2005
Your 1995 Bronco has 4 Wheel ABS (4WABS). The 4WABS controller is located on the driver side of the engine compartment near the front headlight.
For reference
I believe retrieving the codes from that module is different than the older RABS controller. Some info from Steve83: 4WABS Info
The VSS signal goes through the 4WABS controller instead of in parallel like the RABS controller on the F-series.
Wbrann51
Dec 15, 2018 06:18 PM
txazguy
6.7L Power Stroke Diesel
Mar 24, 2017 04:47 AM
MR.NITE
Jul 8, 2013 08:14 AM
TexasGuy001
32
Dec 1, 2010 04:31 PM
robs01f250
Jul 26, 2010 11:25 AM
