Cleaning engine bay
Old May 20, 2009 | 07:33 AM
  #46
RedBoat's Avatar
RedBoat
Rather Be Floatin
Originally Posted by bdrummonds
Wuss! Put your big girl panties on and clean that engine
LMAO
Old May 20, 2009 | 07:52 AM
  #47
megawatt00's Avatar
megawatt00
Originally Posted by 7.3 Rocket
Lisa thanks for the tip on the baking soda/water, but Jim told me that what works even better is Coke and them something (I'm forgetting the name hopefully Jim chimes in) that you can put on that'll keep it from corroding.
Originally Posted by Smokin'
If you can keep the Coke contained (from getting all over everything) yeah it'll work too, probly better because of the carbonation - but same general chemical reaction. I never liked to use it because its really sticky from all the sugar that's in it.
The Anti-Corrosion spray, there are lots of brands. Jim, being the magician electrician that he is, probly has a favorite.
I use a product called Noalox. It is made by Ideal Industries. You can find it in the electrical aisle at HD or Lowes. It is an electrically conductive oxide inhibiting compound. We use it on aluminum wire connections to prevent them from oxidizing.
Old May 20, 2009 | 09:34 AM
  #48
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I will tell y'all how I clean mine, again. . I take the 6637 and hose off at the bracket where the ccv goes in. I stuff rags inside the tube to keep the water out. I use a wash down gun on air line coming from air compressor, I stick the suction hose into a gallon jug of Simple Green and with air psi, I spray it full strength. It's dripping off the bottom of the engine. I spray through the fender wells, under the engine, all over the trans, everywhere. I have never covered anything on the engine, I just don't soak the electrical parts to much. I let it set for a few mins and if there is a stubborn spot, I use a paint brush to scrub. I then take a water hose and wash everything, in the cracks, between things, everywhere. I spray from the wheel wells under the engine, under the trans. I then use the gun to spray air to get the excess water off. Then I crank the engine and let it run for a few mins to dry everything up. I then use Tire Shine in a spray bottle. I spray all the plastic parts and use a rag to get the excess off.
OH, don't forget to take the rags out of the intake before cranking. And put the clean tub and filter back in place. I do this every 2-3 months, and have done this from day one, 9-9-2000. Thats why it looks like it does. I know it would be harder to clean an engine that is 8-10 years old if it never been cleaned before.
<CENTER itxtvisited="1"></CENTER>
Old May 20, 2009 | 10:37 AM
  #49
DieselCamper01's Avatar
DieselCamper01
Good write up Pete. I don't get too worked up about covering everything either.
Old May 20, 2009 | 11:28 AM
  #50
spdmpo's Avatar
spdmpo
Now that I see Miller's pics it all makes sense to me. The beer is the key to doing this and appears to be the most important step. I shall take this new knowledge give it a shot, sans the girl panties.....
After I install the coolant filter than arrived today. Woot!
Old May 20, 2009 | 12:43 PM
  #51
Smokin''s Avatar
Smokin'
Smokin
Rick...that is disgusting...
disgustingly spotless.
geezus.
makes me feel guilty that my motor does not look like that. Is the beer can permanently installed?
Oh Snap!
Old May 20, 2009 | 12:53 PM
  #52
miller_feed
Thanks Lisa, no the beer has to be able to move around. But that can is the best tip I can give for a clean engine.
Old May 24, 2009 | 07:41 PM
  #53
rat49f6's Avatar
rat49f6
i went to the middletown ny big lots today for dupont tire shine and they had everything but
worst part is i was so excited because it was the grand opening today
guess ill have to go to the other one thats anohter 30 min farther away
Old May 24, 2009 | 07:57 PM
  #54
7.3 Rocket's Avatar
7.3 Rocket
Did everything but the tire shine today. Took me a bottle and a half of Simple Green and a full roll of paper towels. I've got to get some more tire shine. I'm out right now. I thought I had some.
I did find out that my IC boots are originally blue. Not black.
Old May 25, 2009 | 01:33 PM
  #55
surveyguy's Avatar
surveyguy
thanks for the write up Rick, and thanks Pete for bringing this up, blue? ha! yup. How about a couple pic's?
Rick, You're right about going from day-1. my '94 F150 is clean, had it from day one. had the F250 only 2 months, and the other guy had it in a dusty-dirty part of the state. Also helps to never have an oil leak.
broncoderek
Aug 6, 2012 07:41 PM
flip4eva83
Apr 25, 2012 11:51 PM
tseng19
2004 - 2008 F150
Mar 27, 2012 07:33 AM
deedzhq
Aug 4, 2011 12:10 PM
poormansrodshop
24
Nov 6, 2009 07:15 AM
