Factory Tow hooks
Old May 18, 2009 | 12:40 PM
oem78's Avatar
oem78
Factory Tow hooks
This is for NUMBER DUMMY. First of all thanks for all your information you provide on this forum. I went to my local wrecking yard yesterday, they have totally re-organized it and brought in some 1978-79 Bronco's and 1977-79 F 150's. I found four Broncos with front tow hooks and two F150 4x4 with tow hooks. They all look the same so must be factory. The guy in the yard said they were rare to find on the 78-79 bronco and F150. Is this true? I pulled a set off of a 1979 Bronco and a 1979 F150 Here are the numbers, can you confirm that these are Ford parts. One set of tow hooks read L 1257 US382 Z11 and R 1257 US382 Z12. The other set reads 1257 L US328 82 and 1257 R US328 82.
Another reason I believe they are ford factory: The holes in the tow hooks match up perfectly with the factory holes in the frame of both Bronco and F150. Also what are the chances that five fords with front tow hooks have the exact same tow hook.Thanks again for any information. OEM
Old May 18, 2009 | 01:21 PM
reynard101's Avatar
reynard101
You may or may not have done this, but sending Number Dummy a PM will get you a much quicker response. At the same time, thanks for sharing by posting, I'm interested in this information as well.
Old May 18, 2009 | 05:21 PM
ranger429's Avatar
ranger429
Two types of factory tow hooks that looked like these. You'll notice that the hooks are offset as well. If you ever find a set of straight hooks they are not factory correct.
NOS set in my basement.
This is the more common type.
I can't tell you the part numbers because I don't have a book yet..... hint, hint Bill.
Old May 18, 2009 | 11:33 PM
Jermafenser's Avatar
Jermafenser
Part numbers? It's right there on the box...
D9TZ17A954A
D9TZ17A955A
Old May 19, 2009 | 01:31 AM
fmc400's Avatar
fmc400
MSEE
ranger429 - if you don't mind me asking, how much did those run you? I remember a thread on here a long time ago on these. In fact, I remember it turning into a huge flame war, because while they're usually expensive in the first place (from what I've seen at least), some guy on here was charging a ridiculous amount of money on eBay for them while providing false information. That thread got pretty wild! Sorry for the thread hijack!
Old May 19, 2009 | 06:09 AM
ranger429's Avatar
ranger429
D9TZ17A954A
D9TZ17A955A
I knew that Chad, I don't know if the bottom picture is a different part # than the set I have.
fmc, I traded a set of red light up visors for them that I got out of a parts Bronco I stripped. I also remember that thread your talking aboout.
Old May 20, 2009 | 01:27 AM
Jermafenser
They are the same set. Only one number is different, and that's because it denotes sides.
D9TZ17A954A - 1979 F150 4/W/D from Serial #FE0001 - RH
D9TZ17A955A - 1979 F150 4/W/D from Serial #FE0001 - LH
Old Nov 5, 2012 | 09:34 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by thatK30guy
Reread the other thread.
You're wrong, the D8 tow hooks are the less hefty hooks, the D9 tow hooks are more beefy, that's plainly obvious in Ranger429's pics of his D9 tow hooks and D8 tow hooks below.
RARE Ford F Series Truck Bronco 4x4 Tow Hooks 73 79 | eBay
Old Jul 19, 2018 | 12:07 AM
Aaron-71's Avatar
Aaron-71
Brining back a thread from the dead.
Does anyone have measurements (centre to center) for these old Tow hooks?
how about a picture of them installed on a truck?
lastlty, do these fit in the same factory locations on an F250 as opposed to an F150/Bronco?
ive been looking up under my F250 and I don't see a great spot to mount something like this given that I've got leaf suspension on all four corners. Wondering if this was an F150 option only.
wtagye
All Things Towing
24
Aug 19, 2017 05:29 AM
hav24wheel
Offroad & 4x4
137
Nov 1, 2016 10:42 AM
dynamic
Ford Truck Parts for Sale
Jun 20, 2016 10:22 AM
dledm
Nov 15, 2012 05:23 PM
oem78
Jul 23, 2010 07:24 PM
