Water Temp. Gauge
Old Sep 18, 2007 | 01:15 PM
johnsjsj's Avatar
johnsjsj
Water Temp. Gauge
I just added a few more gauges to the truck. EGt. -- Boost -- Tranny Oil Temp. -- Engine Oil Temp. -- Volt meter -- and Water Temp. My Question is: Whats the best place to put the sensor for the Water Temp. Gauge? Everything else is installed.
Thanks for the help
Old Sep 18, 2007 | 01:25 PM
IDPisan's Avatar
IDPisan
I put mine on the water pump. There is a plug on the right hand side, if I remember correctly it use an allen wrench. The sensor will screw into that hole.
Old Sep 18, 2007 | 01:48 PM
empiretc's Avatar
empiretc
Yes sir. that is where I put mine. Even in the 100 weather, my temps are averaging between 180-190.
Old Sep 18, 2007 | 02:19 PM
jtharvey's Avatar
jtharvey
180-190? My sensor is in the external coolant filter mount, and I typically see around 210* when fully warmed up. Around town it might be a little lower, but out on the highway, it's right at 209 most all the time. That is also with a 203* thermostat.
Old Sep 18, 2007 | 02:33 PM
empiretc's Avatar
empiretc
I still have the stock thermo. I really couldn't see changing to a 203 considering how hot it is here where I live.
Old Sep 18, 2007 | 02:35 PM
IDPisan's Avatar
IDPisan
I am at 190* when fully warmed up and at normal highway speeds.
Old Sep 18, 2007 | 10:07 PM
DaveWilliams's Avatar
DaveWilliams
I had mine down on the water pump, but when I added an external water filter, I installed the temp sensor up on the filter head and it seemed to decrease the temp by 5* or so. I just got home towing in 105 heat through the mountains and with the stock factory thermostat, I only saw 210 with my 9500# fiver behind me. Mine averages between 200 and about 205 with a peak of 210. This is also with the sensor mounted on the filter housing....your results may vary but I like having my filter so I can use this as a guide, and it seems pretty accurate as far as I can tell.
turbill
43
Jul 31, 2011 12:38 AM
06truck ED
Aug 25, 2010 07:39 PM
got2befast
Jul 17, 2010 07:10 AM
Motoxman_117
May 5, 2009 07:53 PM
Nice Work Truck
Jul 28, 2008 11:23 PM
