Swapping NP435's
Old Aug 13, 2016 | 09:18 AM
chukar's Avatar
chukar
Swapping NP435's
Any reason I can't replace my God-awful NP435 with a rebuilt, such as some change between production years?
Thanks.
Old Aug 13, 2016 | 09:42 AM
Rollingscrapmetal's Avatar
Rollingscrapmetal
Is it 4wd as that makes a difference I believe the really old ones had a different shift pattern
Old Aug 13, 2016 | 10:19 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
NP435 = aluminumtop cover w/8 bolts
T-18 = cast iron top cover w/6 bolts WarrantyPlate TRANS code:A=NP435 (N-1965 only) /F=Warner T-18 /P=F350 Warner T-19.
Warnershift lever retainer cap (8MTH-7220)threads on/off.
NP435 shift lever retainer cap (B8T-7220-D)has two notches, is retained to shift tower by two pins.
To remove this cap, it must be pressed down and held down while turning it counter clock wise to remove it. (Its spring loaded and twists into place, we removed one and it was a2 person job. Put the trans into 2nd, 4th, or reverse, then one person holds the cap and applies pressure, twisting in a counter clockwise direction. The other person hits it from the top with a hammer to get the cap to go in below the two clips that hold it in.) People unaware use pliers or channel locks to remove it, which tears out the pins.
Originally NP435: Reverse-down towards the seat while Warner T-18: Reverse-uptowards the dash.
The reverse shift pattern was changed circa 1973, reverse is down towards the seat.
"1965/72 Warner T-18: Reverse is up-towards the dash. Shift pattern changed in 1973, reverse is down, towards the seat.
1965/72 New Process 435: Reverse is down, towards the seat. AFAIK, it's still that way."
Note:There's another 4 speed: RUG SR-OD Single Rail 4 Speed Overdrive introducedin 1978 F100/150 300/302, TRANS code B
Old Aug 13, 2016 | 11:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The reverse shift pattern was changed circa 1973, but I can't recall for which of these 4 speeds.
Old Aug 13, 2016 | 11:14 AM
chukar's Avatar
chukar
Originally in an F150 and from there into an early year Bronco
Old Aug 13, 2016 | 11:38 AM
77&79F250's Avatar
77&79F250
ND If you are updating MY info, then you are updating YOUR info. I copied if from you years ago. lol
Old Aug 13, 2016 | 12:04 PM
NumberDummy
If you copied my info (so what else is new? ) years ago, why didn't you mention the T-18's different shift patterns?
Hmmm...I now see that you've edited your post to add the shift pattern info.
Old Aug 13, 2016 | 06:53 PM
77&79F250's Avatar
77&79F250
Yea, so what else is new...nothing. I cannot up date that entry in my info thread. So I will repost the correct info in a thread update. BAM
wpnaes
S. California Chapter
57
Apr 28, 2021 02:33 PM
wa-sleeper
Jul 8, 2018 12:01 AM
Cody LaFata
Dec 15, 2015 11:50 PM
Chris Popanz
Nov 26, 2015 03:09 PM
Zip
British Columbia
Sep 30, 2008 02:10 AM
