Sponsored by: Auxito
Transmission fluid?
Old May 15, 2009 | 07:26 AM
twp's Avatar
twp
Transmission fluid?
It havs been a while since I have been on hear. This has probly been aks a hundred times. I have a 01 F150 supercrew 2 wheel drive with a 5.4 that I am going to drop the pan and change the fluid and filter on. How much fluid will I need to put back in it doing it this was?I want to make sure I buy the righ abount when I get it. An the manual said to use MERCON V ATF I thought I read on here a while back that you could not find it anymore. How di I find out which tansmission I have in my truck? Thanks Tim
Old May 15, 2009 | 07:44 AM
l-m tech's Avatar
l-m tech
if its a 4r70w you will need 5 qts if its a 4r100 you will need 6.5 qts.the 4r70w has a almost square pan and the 4r100 has a rectangle pan with a corner cut out on the pass. side.
Old May 15, 2009 | 08:04 AM
olesmoky's Avatar
olesmoky
Mercon V is still available. Check with your local auto parts store.
Old May 15, 2009 | 12:22 PM
twp's Avatar
twp
Thank everyone!!
Old May 15, 2009 | 02:32 PM
twp's Avatar
twp
I just checked it looks like a square but both back corners tapper on a little.
Old May 15, 2009 | 02:48 PM
twp's Avatar
twp
Ok Ifound this post from awhile ago that broke down the door sticked and it said I had a <TABLE style="BORDER-BOTTOM: black 1.5pt solid; BORDER-RIGHT-STYLE: none; BACKGROUND-COLOR: silver; BORDER-COLLAPSE: collapse; BORDER-TOP-STYLE: none; BORDER-LEFT-STYLE: none" border=1 cellSpacing=0 cellPadding=0 width=229 fpstyle="9,011111100"><TBODY><TR vAlign=top><TD style="BORDER-BOTTOM-STYLE: none; BORDER-RIGHT-STYLE: none; BACKGROUND-COLOR: #ffffef; BORDER-TOP-STYLE: none; COLOR: black; BORDER-LEFT-STYLE: none; FONT-WEIGHT: bold" width=97 align=middle>U</TD><TD style="BORDER-BOTTOM-STYLE: none; BORDER-RIGHT-STYLE: none; BACKGROUND-COLOR: #ffffef; BORDER-TOP-STYLE: none; COLOR: black; BORDER-LEFT-STYLE: none" width=116 align=middle>AODEW/4R70W</TD></TR></TBODY></TABLE>
Old May 15, 2009 | 08:53 PM
steve(ill)'s Avatar
steve(ill)
if you remove the ppan, you need 5 quarts. if you look under the bell houisng thru the 2 inch diameter hole, the torque converter has a small drain plug, about the size of a 1/8 pipe plug. you may have to bar the flywheel around with a big screw driver on the teeth to get to the plug. The converter holds 8 more quarts if you drain that. If you have never changed the oil, it would be a good idea to do the converter also. If you remove the plug, loctite it back in. The oil is MERCON V. That is the new stuff. The old MERCON is what is being phased out, not the newer V.
Old May 16, 2009 | 10:06 AM
twp's Avatar
twp
Thanks Steve(ill) I bought it used and dont know if it has ever been changed. I will try to do the torque converter.
Old May 16, 2009 | 11:32 AM
shorebird's Avatar
shorebird
Owners manual here; http://www.motorcraftservice.com/pub.../01f12og4e.pdf
Page 263 lists fluid capacity. 4R70 13.9 quarts Mercon V for complete drain and replace. Do not forget the cooler capacity.
kawika
49
Jun 23, 2021 11:47 PM
BAD RONALD
Jun 10, 2013 09:48 PM
xplorerboy
Dec 6, 2009 07:48 PM
Redranger03
1983 - 2012 Ranger & B-Series
Oct 1, 2009 03:48 PM
TallPaul
Oil & Lubrication
Jun 1, 2004 06:07 PM
