Setting Pinion Angle
Old May 17, 2009 | 11:01 PM
  #31
2losteve's Avatar
2losteve
[quote=M.Collis;7512331]
if you throw your trans in neutral and jack up the rear wheels off the ground you can turn the drive shaft by hand. your hands will feel any binding.
That is a great suggestion, which I will do tomorrow morning. Thanx
Old May 18, 2009 | 03:09 AM
  #32
AXracer's Avatar
AXracer
Originally Posted by brucewolff
From what I see in the last picture, your pinion and driveshaft are at nearly at the same angle. In fact it looks like the pinion is angled up rather than down. This may be just an optical illusion. If not, then you need to tilt your pinion down more.
Sorry, but no, I can't think of any possible situation where the nose on the pinion should point down from horizontal.
Steve, how much space is there between the driveshaft and that crossmember/housing at rest also between the axle and the frame? (I can't see any C notches in the frame?) You need to allow for at least 4" of upward movement of the suspension, and have rubber snubbers above the axle long enough that no moving part of the driveline can contact anything solid at full movement. It appears that the driveshaft yoke/U joint bearing caps are what contacted the sway bar, That would immediately damage the U joint bearings resulting in a quick death. If it were mine, I'd flip that sway to behind the axle, or at least to the top of the frame.
Old May 18, 2009 | 10:56 PM
  #33
2losteve's Avatar
2losteve
Originally Posted by AXracer
Steve, how much space is there between the driveshaft and that crossmember/housing at rest also between the axle and the frame? (I can't see any C notches in the frame?) .
AX, there is 2 1/2" from the top of the u-joint to the swaybar tube & 1 3/4" between the top of the axle housing and the poly snubbers inside my C-notch. Not alot of travel, I know, but I like it low and it rides darn good unless I hit a good one. I'm sure that after swinging that pinion up to 4 1/2 degrees that the contact was made. Don't exactly know how I could pre-determine whether it's going to hit now as I don't know how much spring wrap actually occurs.
Old May 19, 2009 | 05:33 PM
  #34
M.Collis's Avatar
M.Collis
i noticed in the picture you did not have any spring clamps on the front half of the springs, installing spring clamps will stiffen the front half of the spring and help prevent the s shape that happens when the spring is under torque..poor mans traction bars.
Old May 19, 2009 | 05:55 PM
  #35
lew52's Avatar
lew52
when you get your pinion angle right you should be good unless you have a spring problem. If you have a problem you can use cal track bars . There bolt on bars & are adjustable . There made for racing but can be used just to stop spring rap & keep a good pinion angle...Calvert racing .. Lew
Old May 19, 2009 | 08:12 PM
  #36
M.Collis's Avatar
M.Collis
those cal tracks are great. very ajustable. and they work.
Old May 20, 2009 | 12:54 AM
  #37
2losteve's Avatar
2losteve
I only have the clamps that attach to the 3rd leaf and tie in the 2nd and main leaf. Oh, and the main leaves are new Eaton items. But installing a couple more clamps further in towards the axle might be an inexpensive and simple antidote.
I took it for a longer 'test' ride today. Got on our smooth flowing freeway system for about 10 miles as well as some surface street stuff. No problem so far, but I was pretty soft on the 'go pedal'.
Old May 20, 2009 | 12:04 PM
  #38
AXracer's Avatar
AXracer
You may consider a pinion snubber if you don't want to increase clearances. They were frequently used on leaf sprung cars from the factory back in the day. A bracket attached to the pinion housing extending over the U joint with a rubber bump stop attached to the top. It was designed to contact a place on a frame crossmember before any contact between the moving parts ccould occur. The Ramchargers Chrysler factory race team used them rather than traction bars by extending the bump stop IIRC. Other racers soon copied.
If you use an additional leaf clamp, install it so it clamps the 2nd to the main leaf ~ 1/2 way between the end of the second leaf and the end of the third leaf only on the front of the spring. You are effectively shortening that leaf, so the ride will stiffen noticably.
Old May 20, 2009 | 12:05 PM
  #39
jim collins's Avatar
jim collins
Hello I'm new to this forum so mayby my opinions not worth anything .I have been building street rods ,trucks ,ect. and doing all my own backyard mechanic work starting in 1956.I agree with BRUCEWOLFF it looks like the pinion nose needs to come down . the only time I have had spring wrap and u-joint problems with modest horse power is with pinion in line with drive shaft and to many spring leaves removed with no clamps put back on springs. I always have a some small amount of angle in the u-joint on both ends.I have a angle finder but all I use it for is to get my carb right and to get the pinion right when I weld on new spring pads.I set the u-joint angle by just looking at it . this may not work for everybody but it has for me since 1956 in many vehicals and never lost a u-joint from normal use in any of my vehicals . Only from abuse. This car hobby is fun I have done it for a long time, to the new ones in the hobby dont make it hard to enjoy, dont make a big problem from a small one, listen to the good advise I see on this forum every day,especealy that from the ones that have been there and done that. my two cents worth.
Old May 20, 2009 | 12:13 PM
  #40
lew52's Avatar
lew52
I agree thats what we have been saying ..You need neg pinion angle . If you have an angle finder you can see where your at & use the shims to change it > lew
Old May 22, 2009 | 12:09 AM
  #41
2losteve's Avatar
2losteve
I do actually now have neg. pinion angle in relation to my engine/trans. As I said earlier, my rearend sets higher than my trans tailshaft and the engine/trans. angle is 4 1/2 degrees. Since I added the shims I reduced the pinion angle from 4 1/2 to between 2 & 3 degrees.
Ax, that snubber idea is something that I had considered also. It would at least keep the u-joints from hitting that tube under hard throttle.
Jointasset
Jul 5, 2016 08:24 PM
sandman3510
Jan 24, 2012 12:17 PM
glosol
15
May 22, 2011 06:33 PM
dave91gt
Jun 15, 2009 11:23 AM
smoky_diesel
Oct 12, 2007 02:58 PM
